Author Topic: Different chamfer routine  (Read 3914 times)
TJAM51
« on: February 21, 2005, 07:54:08 AM »
I am seeking a way to draw a chamfer with a specified distance with the following situations:
1. I have two lines that form a 90 degree corner or attempting to do so.
2. I have a line with another line perpendicular to the first line but when the chamfer is created the first line remains intact....which means a line is simply drawn to form a chamfer.
[/img]
David Hall
  • Automatic Duh Generator
« Reply #1 on: February 21, 2005, 08:03:17 AM »
1. use a chamfer distance of 0 for both lines.
2 I think that if EDGEMODE sysvar is off, the lines will not trim, leaving them intact
TJAM51
« Reply #2 on: February 21, 2005, 08:06:29 AM »
I tried edgemode and nothing happens no matter what I set it to. It has only two setting, 1 and 2.
SMadsen
« Reply #3 on: February 21, 2005, 08:14:06 AM »
TRIMMODE = 0 -> leaves edges intact.
Is that what you're looking for?
TJAM51
« Reply #4 on: February 21, 2005, 08:15:30 AM »
That works great.........thanks
SMadsen
« Reply #5 on: February 21, 2005, 08:26:07 AM »
TJAM51, pick up a copy of sysvardlg.lsp. Just type in "cham", hit the search button and it'll show all sysvars with "CHAM" in their names.
Type in "chamfer", select "Descriptions" and hit the search button. It'll show all sysvars with CHAMFER in the description - e.g. TRIMMODE.
TJAM51
« Reply #6 on: February 21, 2005, 08:40:08 AM »
Thanks....it is really fantastic.... :D
David Hall
« Reply #7 on: February 21, 2005, 08:45:16 AM »
As for the 1st routine,
(DEFUN C:ch0 ()
  (SETQ CH-A (GETVAR "CHAMFERA")
CH-B (GETVAR "CHAMFERB")
A    (ENTSEL "\nPick First Line: ")
B    (ENTSEL "\nPick Second Line: ")
  (setvar "CHAMFERA" 0)
  (setvar "CHAMFERB" 0)
  (COMMAND "CHAMFER" A B)
  (SETVAR "CHAMFERA" CH-A)
  (SETVAR "CHAMFERB" CH-B)
It needs a little work, but it will get you started
TJAM51
« Reply #8 on: February 21, 2005, 12:17:11 PM »
Here is my version
(DEFUN C:chA ()
  (COMMAND "TRIMMODE" "0")
  (setvar "CHAMFERA" 11.0)
  (setvar "CHAMFERB" 11.0)
  (COMMAND "TRIM" "L" "")
  (command "trimmode" "1")
David Hall
« Reply #9 on: February 21, 2005, 01:39:08 PM »
I dont know if it makes much difference, but you can change the trim mode like
(setvar "trimmode" 0)
and (setvar "trimmode" 1)  OR
capture and reset like
(setq tmode (getvar "trimmode))
;later
(setvar "trimmode" tmode)
jermjmm
Re: Different chamfer routine
« Reply #10 on: October 02, 2007, 05:01:43 PM »
I'm haveing a problem with the chamfer also.  what I'm trying to do is I have 2 lines that form a cross and I want to put a chamfer on one of them so you end up with a T with a chamfer (PIC INCLUDED). whenever I try to use the chamfer command inside of lisp (command "chamfer" . . . . . it keeps saying unknown command, I had someone tell me to use this instead (command "_chamfer . . . .  but it still says unknown command.  any ideas?
« Reply #11 on: October 02, 2007, 05:12:14 PM »
Do (command "_.chamfer" .. ) the period is what lets you use the default Acad command (incase it has be redefined), and the underscore lets it work on other Acad's beside the english version.
« Reply #12 on: October 02, 2007, 06:05:18 PM »
