Author Topic: Invoke LISP  (Read 4017 times)
Odoshi
Invoke LISP
« on: December 31, 2011, 11:04:28 AM »
I am trying to invoke LISP, such as:
Dim args As ResultBuffer = New ResultBuffer()
args.Add(New TypedValue(5005, "c:wd_retag_update_noprompts"))
args.Add(New TypedValue(5005, "nil"))
args.Add(New TypedValue(5005, sSymbol_Name))
Dim rbRes As ResultBuffer = Autodesk.AutoCAD.ApplicationServices.Application.Invoke(args)
But AutoCAD returns unknown command.
In LISP, it would look like: (c:wd_retag_update_noprompts nil "SYMBOL")
Shouldn't this run synchronously, just fine?
Thanks,
Mike
gile
  • Marseille, France
Re: Invoke LISP
« Reply #1 on: December 31, 2011, 12:21:28 PM »
Hi
nil is not a string.
use:
args.Add(New TypedValue(CInt(LispDataType.Nil)))or
args.Add (New TypedValue(5019))
Odoshi
Re: Invoke LISP
« Reply #2 on: December 31, 2011, 01:22:50 PM »
Hmm.. I tried it on another and keep getting:
Command: ; error: invalid AutoCAD command: nil
        args.Add(New TypedValue(5005, "c:wd_in_ladder"))
        args.Add(New TypedValue(5010, 1))
        args.Add(New TypedValue(5016))
        args.Add(New TypedValue(5001, 1.8))
        args.Add(New TypedValue(5001, 21.425))
        args.Add(New TypedValue(5001, 0.0))
        args.Add(New TypedValue(5017))
        args.Add(New TypedValue(5001, 18.0))
        args.Add(New TypedValue(5005, "H"))
        args.Add(New TypedValue(5001, 12.5))
        args.Add(New TypedValue(5001, 0.75))
        args.Add(New TypedValue(5010, -1))
        args.Add(New TypedValue(5005, "01"))
        args.Add(New TypedValue(5010, 2))
Is the invoke returning nil, and then AutoCAD receiving it as a command?
Thanks,
Mike
gile
  • Marseille, France
Re: Invoke LISP
« Reply #3 on: December 31, 2011, 01:36:39 PM »
The result buffer must match the way you'd call your LISP function.
Post your LISP expression.
Odoshi
Re: Invoke LISP
« Reply #4 on: December 31, 2011, 02:03:37 PM »
This was the old VB way:
ThisDrawing.SendCommand("(c:wd_in_ladder 1 (list 1.8 21.425 0.0) nil 18.00 " & Chr(34) & "H" & Chr(34) & " 12.5 0.75" _
        '    & " 0.75 1 nil -1 " & Chr(34) & "01" & Chr(34) & " 2)" & vbCr)
which I think equates to:
(c:wd_in_ladder 1 (list 1.8 21.425 0.0) nil 18.00 "H" 12.5 0.75 0.75 1 nil -1 "01" 2)
Maybe I've miplaces a param.
gile
  • Marseille, France
Re: Invoke LISP
« Reply #5 on: December 31, 2011, 02:11:29 PM »
Does the LISP expression work fine ?
Is the LISP file loaded ?
Try replacing:
with
args.Add(New TypedValue(5009, new Point3d(1.8, 21.45, 0.0)))
Odoshi
Re: Invoke LISP
« Reply #6 on: December 31, 2011, 02:27:51 PM »
Yes, I can cut and paste that line of LISP and it gets drawn.
I tried substituting in a Point type for the list of 3 doubles.
        args.Add(New TypedValue(CInt(LispDataType.Point3d), New Point3d(1.8, 21.425, 0.0)))
for the following:
But no joy....
Perhaps it's the context from which I am calling it?
It comes from a button click off a floating palette. But all the block insertion routines before it run fine.
Thanks,
Mike
Odoshi
Re: Invoke LISP
« Reply #7 on: January 03, 2012, 09:17:34 AM »
So I confirmed that I can call the following from the command line:
    <CommandMethod("INVOKE")>
    Public Sub INVOKE()
        args.Add(New TypedValue(5005, "c:ace_update_WFRM2ALL"))
        args.Add(New TypedValue(5003, 1))
But using the code from a Palette on a new document object does not work. The LISP started to run, but bombed out when the LISP tried to return messages.
The command prompt gave:
Any thoughts,
Mike
Odoshi
Re: Invoke LISP
« Reply #8 on: January 03, 2012, 01:55:10 PM »
Judging by this thread http://www.theswamp.org/index.php?topic=39957.0 it looks like AcedInvoke is limited to the one drawing it my command gets called from.
Any tips on how to start a command in one drawing, open another drawing and run some LISP synchronously?
Thanks,
Odoshi
Re: Invoke LISP
« Reply #9 on: January 03, 2012, 02:49:56 PM »
Well, looks like I'll need to add in the Interops. SendCommand will run synchronously if the Session flag is used.
Case closed :)
