Author Topic: Stupid question about control.name  (Read 4658 times)
Ricky_76
« on: June 29, 2006, 07:09:17 PM »
Hi, and tnx 4 your time!
I have a small problem!
I need to refer to some controls dynamically, lets check to the example!
I have 3 disabled combobox (cb_1, cb_2, cb_3) that I need to reenable!
dim i as integer
for i = 1 to 3
     ["cb_" & i].enabled = true
next
I know that in Flash you can refer to a control simply using "[STRING]." it's possible to do in some wai also in VB and VBA???
Actually I use:
dim s as string
dim ctr as control
for i = 1 to 3
    s="cb:_" & i
    for each ctr in me.controls
        if ctr.name=s then
            ctr.enabled = true
        goto cont
        end if
    next
cont:
next
LET ME KNOW!!!! :)
« Last Edit: June 29, 2006, 07:37:17 PM by Ricky_76 »
Bryco
Re: Stupid question about control.name
« Reply #1 on: June 29, 2006, 07:30:07 PM »
Sounds good, do you have a problem?
Ricky_76
« Reply #2 on: June 29, 2006, 07:35:40 PM »
Hi Bryco,
it works very well, but I need to use 12 code lines instead of 4!
and in many other cases (the example i reported is only a simple problem) i need this "Function" massively!
« Reply #3 on: June 29, 2006, 08:07:53 PM »
well, here's a shorter version.....
Dim i As Integer
Dim ctl As ComboBox
For i = 1 To 3
    Set ctl = Me.Controls.Item("cb_" & i)
    ctl.Enabled = True
Next
« Reply #4 on: June 29, 2006, 10:48:38 PM »
not good enough Jeff ... that's 6 lines  :lol:     :lmao:
Bryco
« Reply #5 on: June 29, 2006, 11:03:19 PM »
4
Function ControlOn(sName As String) As Boolean
    Me.Controls.Item(sName).Enabled = True
    ControlOn = True
End Function
Ricky_76
« Reply #6 on: June 30, 2006, 03:25:29 AM »
Dim i As Integer
Dim ctl As ComboBox
For i = 1 To 3
    ctl.Enabled = True
Next
tnx Jeff, I have tested your solution but it doesn't work properly, maybe it works in .net, not in VBA!
I'll test it again later. :)
« Last Edit: June 30, 2006, 03:30:45 AM by Ricky_76 »
Ricky_76
« Reply #7 on: June 30, 2006, 03:26:59 AM »
4
    ControlOn = True
End Function
HI Bryco,
GREAT, it works fine! TNX a lot!
« Last Edit: June 30, 2006, 03:31:16 AM by Ricky_76 »
Ricky_76
« Reply #8 on: June 30, 2006, 03:29:56 AM »
 :-D  :-D  :-D
Bob Wahr
« Reply #9 on: June 30, 2006, 10:38:06 AM »
4
[buzzer]
WRONG!
It being a function, you need a line to call it so it's 5 not 4
« Reply #10 on: June 30, 2006, 12:08:27 PM »
FYI, I only tested that in VBA.....it worked fine for me. But I like Bryco's Function better. :-)
Ricky_76
« Reply #11 on: June 30, 2006, 12:19:54 PM »
Hi, you're right!
It works!  8-)
thx!
