Author Topic: Need help with DCL File  (Read 3626 times)
Dave M
« on: February 18, 2014, 02:49:46 PM »
I have been using this routine to put xrefs on a specific layer for years.  It has a problem though, the dialogue box doesn't work as expected.  I don't have the skill set to fix it.  There's not many lines of code, so I was hoping one of you "brainiacs" out there would be willing to fix it for me.
Thanks for looking!
Civil 3D 2018 - Microstation SS4 - Windows 10 - Dropbox
Matt__W
  • I like my water diluted.
Re: Need help with DCL File
« Reply #1 on: February 18, 2014, 03:17:40 PM »
Try the attached...
Autodesk Expert Elite
snownut2
  • Bricscad 22 Ultimate
« Reply #2 on: February 18, 2014, 03:43:54 PM »
Really not the place for this thread....
Matt__W
« Reply #3 on: February 18, 2014, 03:44:33 PM »
snownut2
« Reply #4 on: February 18, 2014, 03:49:07 PM »
On a side note, I could never get the mnemonic option to work in DCL
Dave M
« Reply #5 on: February 18, 2014, 03:54:23 PM »
Can you tell me where the appropriate place is so I know for next time?
Matt__W
« Reply #6 on: February 18, 2014, 03:59:56 PM »
I see now.  The OP posted in "SHOW YOUR STUFF" when it should've been in AutoLISP (Vanilla / Visual).
« Reply #7 on: February 18, 2014, 04:52:28 PM »
Modified version with No DCL
  1. ;;;written by  Michael P. Fowler
  2. ;;;09/16/98
  3. ;;;written for Rainer Will
  4. ;;;written in R14
  5. ;;;put xrefs on layers that are equal to the xref name
  6.
  7. ;;;  Modified by CAB 02/18/2014
  8.
  9. (defun c:xlayer (/ lname ent elist blist xass xcat xlname xlay)
  10.   (alert (strcat "This will change the layer of the selected XREF"
  11.                  "\nto a layer named 0_xx \nwhere xx is the name of the xref" )
  12.   )
  13.
  14.   (if (and
  15.         (setq ent (car (entsel "Pick xref to change layer name to match xref name: ")))
  16.         (setq xass (cdr (assoc 2 (setq elist (entget ent)))))
  17.         (setq blist (entget (tblobjname "BLOCK" xass)))
  18.         (= 4 (logand (cdr (assoc 70 blist)) 4))
  19.   )
  20.     (progn
  21.       (setq lname (getvar "clayer")
  22.             xlay  (cdr (assoc 8 elist))
  23.             xcat  (strcat "0_" xass)
  24.       )
  25.       (command ".layer" "m" xcat "")
  26.       (setq xlname (getvar "clayer"))
  27.       (command ".layer" "u" xlay "")
  28.       (command "change" ent "" "P" "la" xlname "")
  29.       (command ".layer" "lo" xcat "")
  30.       (setvar "clayer" lname)
  31.       (princ (strcat "\nThe xref---" xass "---is now on the---" xcat "---layer")
  32.       )
  33.
  34.     )
  35.     (princ "\nUser Quit or picked non-Xref object....")
  36.   )
  37.   (princ)
  38. )
  39.
Dave M
« Reply #8 on: February 18, 2014, 05:59:58 PM »
Thanks M@yhem for fixing the DCL, it works great.  Thanks Charles for the no-DCL version.  I think I like it best!
« Reply #9 on: February 18, 2014, 06:18:36 PM »
Some icing for the selection:
  1. (defun c:xlay ( / xl xn xr )
  2.     (while
  3.         (progn (setvar 'errno 0) (setq xr (car (entsel "\nSelect xref: ")))
  4.             (cond
  5.                 (   (= 7 (getvar 'errno))
  6.                     (princ "\nMissed, try again.")
  7.                 )
  8.                 (   (null xr) nil)
  9.                 (   (or (/= "INSERT" (cdr (assoc 0 (setq xr (entget xr)))))
  10.                         (zerop (logand 4 (cdr (assoc 70 (tblsearch "block" (cdr (assoc 2 xr)))))))
  11.                     )
  12.                     (princ "\nSelected object is not an xref.")
  13.                 )
  14.                 (   t
  15.                     (lock-unlock-layer (cdr (setq xl (assoc 8 xr))) nil)
  16.                     (entmod (subst (cons 8 (setq xn (strcat "0_" (cdr (assoc 2 xr))))) xl xr))
  17.                     (lock-unlock-layer xn t)
  18.                     nil
  19.                 )
  20.             )
  21.         )
  22.     )
  23.     (princ)
  24. )
  25. (defun lock-unlock-layer ( lay lck / dxf enx )
  26.     (if (setq enx (tblobjname "layer" lay))
  27.         (progn
  28.             (setq enx (entget enx)
  29.                   dxf (assoc 70 enx)
  30.             )
  31.             (entmod (subst (cons 70 (boole (if lck 7 4) 4 (cdr dxf))) dxf enx))
  32.         )
  33.     )
  34. )
Dave M
« Reply #10 on: February 18, 2014, 07:58:56 PM »
Thanks Lee! I always appreciate your input!
Dave
Bhull1985
« Reply #11 on: February 19, 2014, 07:40:50 AM »
  2.     (while
  4.             (cond
  7.                 )
  8.                 (   (null xr) nil)
  11.                     )
  13.                 )
  14.                 (   t
  18.                     nil
  19.                 )
  20.             )
  21.         )
  22.     )
  23.     (princ)
  24. )
  27.         (progn
  30.             )
  32.         )
  33.     )
  34. )
Found another one just like the previous Lee :D
                (   (null xr) nil)
I see how you're using it, with your description and the alternate routine, interesting! I think I may have to incorporate this as well because it seems as if it'd be the proper way to handle a user right clicking through a routine.
« Reply #12 on: February 19, 2014, 06:21:52 PM »
Dave
You're welcome Dave!  :-)
There are many ways to skin a cat in AutoLISP  ;-)
