The above image shows the south-west corner of the site in the first image and the merged design and natural ground surface. I have a variable width, constant grade assembly applied with it targeting to the variable pavement extents, then a batter down/up to the natural surface.
The frequency of the sample lines in the corridor is large so as that the shape of the variable width pavement is followed closely.
In the areas where the assembly width has varied suddenly and increased in width, the elevation has increased also (which is fine) although the contours generated then are not representative of what would occur in reality. In reality they would be battered down on an angle between the change in assemblies, not perpendicular like shown in the above picture. I can't work out how to try and achieve this and would appreciate some help.
If I decrease the frequency of the sampling within the corridor, the batter contours are improved a bit although the assembly does not then follow the shape of the variable width pavement well enough.
I'm still not sure how I would model the driveways/areas where there is no kerb without breaking the corridor into 30 or so regions, and even then I don't think that would work for the driveways that are perpendicular to the road centreline (yet also have kerb perpendicular to the centreline as well at the same station).
