Code Red => VB(A) => Topic started by: Dan on July 14, 2008, 03:01:46 PM
How would I Explode an AutoCAD Table object? I have created a sset of
tables, and wish to explode them into individual entities.
Any clues about how I should obtain this?
Thanks,
Dan
'code snippet
Dim Ent As AcadEntity
Dim oTable As AcadTable
Dim oSet As AcadSelectionSet
FilterType(0) = 0
FilterData(0) = "ACAD_TABLE"
Set oSet = ThisDrawing.SelectionSets.Add("DeleteTable")
oSet.Select acSelectionSetAll, , , FilterType, FilterData
For Each Ent In oSet
Set oTable = Ent
oTable.Explode 'obviously this will not work
Next
Hi Dan
Here is a dirty method but seems to be worked
for me
Option Explicit
Sub XplodeTest()
Dim FilterType(0) As Integer
Dim FilterData(0) As Variant
FilterType(0) = 0
With ThisDrawing.SelectionSets
While .Count > 0
.Item(0).Delete
Wend
Set oSet = .Add("DeleteTable")
End With
Set oTable = Ent
'''oTable.Explode 'obviously this will not work
Dim hdl As String
hdl = oTable.Handle
Dim strcom As String
strcom = "EXPLODE" & Chr(32) & "(handent " & Chr(34) & hdl & Chr(34) & ")" & vbCr & vbCr & vbCr
ThisDrawing.SendCommand strcom
Next Ent
SendKeys "{ESC}"
DoEvents
~'J'~
Thank you for the clever approach. I personally hate to use sendcommand for anything, but I have yet to find a method through VBA. Thank you again. This will work for my needs.
You're welcome
Cheers :)
~'J'~
