Author Topic: Workin' the layers collection yada ...  (Read 2942 times)
« on: April 14, 2005, 03:52:41 PM »
(defun LayMods ( predicateFunction trueFunction elseFunction / foo )
    ;;  trivial code, nonetheless © 2005 Michael Puckett
    ;;  you are free to use in your code, just give a nod
    ;;  to the author and where you found this ;]
    ;;  predicateFunction must take one parameter, a layer
    ;;  object and return a nil or non nil result
    ;;  trueFunction must take one parameter, a layer object;
    ;;  what it actually does is up to the caller. It may be
    ;;  nil if the caller wishes to do nothing when the
    ;;  predicateFunction returns a non nil result.
    ;;  elseFunction must take one parameter, a layer object;
    ;;  predicateFunction does not return a non nil result.
    ;;  no error trapping is done here in the interests of
    ;;  svelte programming, the caller is responsible for that
    (eval
        (append
           '(defun foo (layer))
                (   (and
                        (eq 'subr (type trueFunction))
                        (eq 'subr (type elseFunction))
                   '(   (if (predicateFunction layer)
                            (trueFunction layer)
                            (elseFunction layer)
                (   (eq 'subr (type trueFunction))
                (   (eq 'subr (type elseFunction))
                   '(   (if (null (predicateFunction layer))
                (   t
                    ;;  apparently caller wants to do nothing
                    ;;  via the true or else functions. However,
                    ;;  let's assume something is done in the
                    ;;  predicate function, and we need to fulfil
                    ;;  the contract by applying the predicate
                    ;;  function to every layer object
                   '((predicateFunction layer))
    (vlax-for layer
        (vla-get-layers
            (vla-get-activedocument
                (vlax-get-acad-object)
        (foo layer)
Some examples --
Employing a true function only --
;;  lock all layers where the first two characters
;;  are the same, like "AA-Concrete" or "BB-Steel",
;;  otherwise do nothing
(defun c:NameMePlease ( )
    (LayMods
        (lambda ( layer / lst )
            (eq
                (car
                    (setq lst
                        (vl-string->list
                            (strcase
                                (vla-get-name layer)
                (cadr lst)
        (lambda ( layer )
            (vla-put-lock layer :vlax-true)
        nil
;;  thaw and turn on all layers unconditionally
(defun c:ThawAll ( )
    (LayMods
        (lambda ( layer ) t)
        (lambda ( layer )
            (vl-catch-all-apply
               '(lambda ()
                    (vla-put-layeron layer :vlax-true)
                    (vla-put-freeze layer :vlax-false)
        nil
Employing true and else functions --
;;  characters are the same, like "AA-Concrete"
;;  or ""BB-Steel", otherwise unlock the layer
(defun c:NameMePlease2 ( )
    (LayMods
            (eq
                (car
                    (setq lst
                        (vl-string->list
                            (strcase
                (cadr lst)
        (lambda ( layer )
        (lambda ( layer )
            (vla-put-lock layer :vlax-false)
;;  freeze and turn off all xref layers,
;;  otherwise thaw and turn on layer
(defun c:XRefsOff ( )
    (LayMods
        (lambda ( layer )
            (wcmatch
        (lambda ( layer )
            ;;  error trap an attempt to
            ;;  freeze the current layer
            (vl-catch-all-apply
               '(lambda ()
                    (vla-put-layeron layer :vlax-false)
                    (vla-put-freeze layer :vlax-true)
        (lambda ( layer )
            (vl-catch-all-apply
               '(lambda ()
Employing an else function only --
;;  isolate the current layer
(defun c:isolate ( / clayer )
    (setq clayer (getvar "clayer"))
    (LayMods
        (lambda ( layer )
            ;;  oh my, using local global
            (eq clayer (vla-get-name layer))
        nil
        (lambda ( layer )
Employing neither true or else functions --
;;  print all colors (don't actually do
;;  anything to any of the layers)
(defun c:LayColors ( )
    (princ "Layer colors:\n")
    (LayMods
        (lambda ( layer )
            (princ
                (strcat
                    (itoa (vla-get-color layer))
                    "\n"
        nil ;; do nothing
        nil ;; what ^ said
etc.
(I didn't actually test these examples, if you find an insect let me know).
If you're still with me I use this technique at a slightly higher level -- rather than code for a specific collection like the layers collection, I use it for any collection, passing the collection to the overall wrapper --
(defun ModifyCollection ( collection predicateFunction trueFunction elseFunction )
    (eval
        (append
           '(defun foo (object))
    (vlax-for object collection
        (foo object)
But in the interests of initial clarity I coded it as offered above.
Oops, did I go and share too much info again?
« Reply #1 on: April 14, 2005, 05:04:02 PM »
The mother lode................. WE'VE STRUCK GOLD BOYS
« Reply #2 on: April 14, 2005, 05:49:30 PM »
Might be considered a load all right ...
« Reply #3 on: April 14, 2005, 07:25:42 PM »
Nice Mr P.
Yousa sick puppy.
« Reply #4 on: April 14, 2005, 08:21:53 PM »
Thanks Kerry (I think). :oops:
In the remote chance you're interested ...
(defun ForEachObject ( collection predfunc thenfunc elsefunc / func )
    ;;  the predicate function must take one parameter, an
    ;;  the then function must take one parameter, an object;
    ;;  be nil if the caller wishes to do nothing when the
    ;;  predicate function returns a non nil result.
    ;;  the else function must take one parameter, an object;
    ;;  predicate function returns a nil result.
    ;;  svelte programming, the caller is charged with that
    ;;  resposibility
    (   (lambda ( then else )
            (eval
                (append
                   '(defun func (object))
                        (   (and then else)
                           '(   (if (predfunc object)
                                    (thenfunc object)
                                    (elsefunc object)
                        (   then
                                    (thenfunc object)
                        (   else
                           '(   (if (null (predfunc object))
                                    (elsefunc object)
                        (   t
                           '((predfunc object))
        (eq 'subr (type thenfunc))
        (eq 'subr (type elsefunc))
    ;;  why all the above crud you may ask yourself
    ;;  well ... the above is done only once per
    ;;  call, rather than checking the then and else
    ;;  functions each iteration thru the collection
    ;;  just a wee bit more efficient :]
        (func object)
