By inserting a block with the name preceded by *, the block is exploded upon insertion. Is there a method to capture a list of the entities within the block prior to exploding, the entities must already be located in the drawing however so that the DXF values are correct. (the entities in this case are attributes)
This list could be either a Selection Set List or Entity List.
I would like to use this list of entities to subsequently create a new block with additional entities in it.
I have no problems converting this entity list into a selection set for the subsequent block command.
Thanks,
Bruce
