Author Topic: Delete Block Table entity  (Read 6847 times)
cadman6735
« on: April 25, 2011, 02:32:01 PM »
Hi all
I am practicing with the following code
(defun c:test ( / )
  (setq sset (ssget "_X" '((0 . "INSERT"))))
  (setq cnt 0)
  (repeat (sslength sset)
    (setq
  ent (ssname sset cnt)
  entData (entget ent)
  entName (strcase (cdr (assoc 2 entData)))
      (wcmatch entName "*SEAL*,*SIG*")
      (entdel ent)
    (setq cnt (1+ cnt))
I am trying to figure out how to delete a table entity in vanilla lisp without using purge command.
thanks
« Last Edit: April 25, 2011, 03:20:21 PM by cadman6735 »
Tharwat
  • Hypersensitive
Re: Delete Block Table entity
« Reply #1 on: April 25, 2011, 02:55:44 PM »
I guess it should be like this . :-)
(wcmatch (strcase entName) (strcase "*SEAL*,*SIG*"))
cadman6735
« Reply #2 on: April 25, 2011, 03:00:51 PM »
Hi Tharwat
Your post confusses me...   I have already strcase my entName up in my setq.
I am having no trouble deleting the blocks from my drawing, I am looking to purge the block from the file without using the purge command in my lisp routine, only deleting the table enity using Vanilla lisp.
I can find plenty of examples with purge in the lisp function and plenty of examples deleteing the table entity via Visual Lisp, but having a problem finding an example using vanilla lisp.
Edit
but I do like your technique better of where you place the strcase for entName.
Changed my repeat to match your suggestion...  Thanks
    (setq
  entName (cdr (assoc 2 entData))
      (wcmatch (strcase entName) "*SEAL*,*SIG*")
      (entdel ent)
    (setq cnt (1+ cnt))
« Last Edit: April 25, 2011, 03:24:12 PM by cadman6735 »
gile
  • Marseille, France
« Reply #3 on: April 25, 2011, 03:29:53 PM »
I think it's not possible using 'Vanilla LISP': the entdel function do not work with BLOCK neither with BLOCK_RECORD.
What's the matter with Visual LISP ?
You can have a look yo this thread.
« Reply #4 on: April 25, 2011, 03:32:44 PM »
What Gile said:
;;No workie
(and (setq blk (tblobjname "block" "test")) (entdel (cdr (assoc 330 (entget blk)))))
;;Workie
     (vla-delete (vlax-ename->vla-object (cdr (assoc 330 (entget blk)))))
cadman6735
« Reply #5 on: April 25, 2011, 03:43:17 PM »
Thanks guys
There is nothing wrong with using visual lisp or using the purge command
I am just practicing and wanted to know how to delete a table entity via vanilla lisp, but if it can't be done with vanilla lisp then I have learned what I desired to know...
This is probably why I could not find any examples of how to do it...   :wink:
I will use ronjonp example
So is it save to assume that I can not delete any table entity via vanilla lisp?
Thanks again.
cadman6735
« Reply #6 on: April 25, 2011, 03:57:03 PM »
gile
Just read your post to the link you provided...
Thanks this will help very much.
cadman6735
« Reply #7 on: April 25, 2011, 05:01:30 PM »
Thanks Ron
Works Great
(defun c:test ( / )
  (setq cnt 0)
     (setq
 entTblName (tblobjname "block" entName)
(entdel ent)
(vla-delete (vlax-ename->vla-object (cdr (assoc 330 (entget entTblName)))))
    (setq cnt (1+ cnt))
« Reply #8 on: April 25, 2011, 05:34:54 PM »
Glad to help  :-)
Did not test but you may want to wrap the vla-delete like this:
(vl-catch-all-apply
  'vla-delete
  (list (vlax-ename->vla-object (cdr (assoc 330 (entget enttblname)))))
I'd imagine if the block was still referenced, it would fail.
cadman6735
« Reply #9 on: April 25, 2011, 05:53:46 PM »
Cool every hint helps, Thanks again Ron
cadman6735
« Reply #10 on: April 26, 2011, 09:49:42 AM »
This is what I finished up with.
I am not sure if this is complete (void of errors) but it seems to work for me.
My next step is to add a (getstring) function to get part of the block name via user input and add it to the (ssget) filter *SEAL* so I can choose different block other than blocks with Seal in the name.
(defun c:delBlock ( / sset cnt ent entData entName entTblName )
  (vla-StartUndoMark acadActiveDocument)
    (setq sset (ssget "_X" '((0 . "INSERT") (2 . "*SEAL*"))))
      (setq cnt 0)
(setq
 (wcmatch (strcase entName) "*SEAL*")
   (entdel ent)
   (vl-catch-all-apply 'vla-delete (list (vlax-ename->vla-object (cdr (assoc 330 (entget entTblName))))))
(setq cnt (1+ cnt))
    (alert "No Block Definition in Drawing")
    (vla-EndUndoMark acadActiveDocument)
cadman6735
« Reply #11 on: April 26, 2011, 03:13:16 PM »
Here it is with the (getstring) for block name user input, I find it dangerouse because it is a total wildcard, it will filter by one letter and get all blocks that contain that one letter or you can spell out a portion of the desired block name to narrow down your selection.
WARNING:  This routine can delete blocks not intended to be deleted if too few letters are used for the selection set filter.
example:  if you enter "s" it will delete every block with an "s" in the name.
              if you enter "seal" it will delete all the blocks with "seal" in the name.
              if you enter "se" it will delete all the blocks with "se" in the name, including "seal" because "se" is part of "seal"
If this routine acts any different to what I explained above, please let me know, for I am a beginner and this makes me dangerouse.
(defun c:TEST ( / blkName sset cnt ent entData entName entTblName )
  (setq blkName (getstring "\nEnter Block Name:  "))
    (setq sset (ssget "_X" (list '(0 . "INSERT") (cons 2 (strcat "*" blkName "*")))))
      (setq cnt 0)
(setq
(entdel ent)
(setq cnt (1+ cnt))
« Reply #12 on: April 26, 2011, 03:29:54 PM »
Hi CADMan,
I would be inclined to approach it in the following way:
(defun c:test ( / name ss i b ) (vl-load-com)
  (setq name (getstring t "\nSpecify Block to Delete <All>: "))
  (if (setq ss (ssget "_X" (list (cons 0 "INSERT") (cons 2 (setq name (strcase (strcat "*" name "*")))))))
        (entdel (ssname ss (setq i (1- i))))
      (while (setq b (tblnext "BLOCK" (null b)))
        (if (wcmatch (strcase (cdr (assoc 2 b))) name)
            (list
                (cdr
                  (assoc 330 (entget (tblobjname "BLOCK" (cdr (assoc 2 b)))))
    (princ "\n--> No Blocks Found.")
Since you needn't try to delete the block definition until all the INSERTs have been deleted.
Note the restrictions:
  • Doesn't account for anonymous Dynamic Block names
  • Doesn't account for Blocks on Locked Layers
  • Doesn't account for nested blocks
Matt__W
  • I like my water diluted.
« Reply #13 on: April 26, 2011, 03:46:15 PM »
It doesn't do much, does it??  It's kinda like the free-loading-college-buddy of LSP routines.  :wink:
Autodesk Expert Elite
alanjt
  • Standby for witty remark...
« Reply #14 on: April 26, 2011, 04:00:34 PM »
It just hangs around and smokes all your pot.
Dropbox
