Author Topic: Zoom extents and Zoom Windows  (Read 6988 times)
FELIX
« on: September 03, 2012, 10:04:58 PM »
Give the zoom Extents and Zoom windows in VB.net?
OK.
Re: Zoom extents and Zoom Windows
« Reply #1 on: September 03, 2012, 10:19:42 PM »
See what you can make from this :
Code - C#: [Select]
  1.         public static void ZoomExtents()
  2.         {
  3.                 // cast as  Autodesk.AutoCAD.Interop.AcadApplication
  4.                 ((AcadApplication)Application.AcadApplication).ZoomExtents();
  5.         }
Code - C#: [Select]
  1.
  2.    public static void ZoomWindow(Point3d lowerleft, Point3d upperRight)
  3.    {
  4.        ((AcadApplication)Application.AcadApplication).ZoomWindow(
  5.            lowerleft.ToArray(), upperRight.ToArray());
  6.    }
  7.
« Last Edit: September 03, 2012, 10:38:05 PM by Kerry »
gile
  • Marseille, France
« Reply #2 on: September 04, 2012, 02:11:49 AM »
You can have a look at the AutoCAD .NET Developper's Guide, There're examples without using COM :
http://exchange.autodesk.com/autocad/enu/online-help/WS1a9193826455f5ff2566ffd511ff6f8c7ca-4369.htm
franciscocsilva
  • Mosquito
« Reply #3 on: September 28, 2012, 12:09:23 PM »
Já conseguiste este código?
FELIX
« Reply #4 on: October 05, 2012, 09:35:29 PM »
em VB.NET ainda não consegui executar.
OK.
« Reply #5 on: October 05, 2012, 10:29:54 PM »
[bing translation] in VB.NET still couldn't run.
Felix, what code did you try ??
