Author Topic: Field not updated when close and open again  (Read 2505 times)
HasanCAD
« on: March 04, 2015, 04:42:32 AM »
I created a block showing the level as a field.
The attribute value should be updated when close and open again.
the value is OK in model but did not updated in layout I have to open the viewport then REGEN then close
System variable FIELDEVAL = 31
Please advice
HasanCAD
Re: Field not updated when close and open again
« Reply #1 on: March 04, 2015, 05:39:49 AM »
I notced that if there is more than one annotation that habben but if there is one annotation only the field updated automaticaly.
is this only the resone? or there is system variable controles that issue?
ChrisCarlson
« Reply #2 on: March 04, 2015, 08:12:38 AM »
So you are pulling the "Y" value and rounding to the nearest hundredths? Everything seems fine here if I insert a new block. One suggestion, set the attribute to preset - yes
HasanCAD
« Reply #3 on: March 04, 2015, 10:21:00 AM »
Insert the block then change annotative then move the block using insertion point (not move comamnd) then back to first annotative.
ChrisCarlson
« Reply #4 on: March 04, 2015, 11:39:24 AM »
Still can't duplicate the issue here with Vanilla 2015 AutoCAD
« Reply #5 on: March 04, 2015, 11:41:46 AM »
sounds more like a problem with your method; than a problem with the field....
IF
what you are doing is causing the field to malfunction
STOP
doing it that way
ChrisCarlson
« Reply #6 on: March 04, 2015, 12:04:35 PM »
If you are pulling elevation, wouldn't you want the Z value?
« Reply #7 on: March 04, 2015, 04:16:59 PM »
they may be using the Architectural definition of the word 'elevation'
NOT the Civil definition; although in some countries to avoid this potential confusion the
Civil persons use the term 'levels' where we in the US might use elevation, i.e. Z value.
HasanCAD
« Reply #8 on: March 05, 2015, 06:07:21 AM »
IF
STOP
doing it that way
Yes most of the problem is because of user method.
The HOD came to me with this problem, PDF file showing a level and DWG file showing another level.
The solution wha tI found is to delete all unused annotative from the objects or insert the block each time.
But I am searching for a solution to avoid the user mistake.
« Reply #9 on: March 05, 2015, 08:54:50 AM »
IF
STOP
doing it that way
Actually the
, is the 'proper' way
technically autocad would prefer that one INSERTS a block each time the block is needed
rather than COPY the block.
That being said; we all know that some people just wont follow that simple advice.
Let me see If I can offer any other help...downloading your block now...
« Reply #10 on: March 05, 2015, 09:08:44 AM »
try this one....it appears to work ...
« Reply #11 on: March 05, 2015, 09:13:05 AM »
Me either...
« Reply #12 on: March 05, 2015, 09:18:48 AM »
it may, just may have to do with REGENAUTO being turned OFF...
and then the user upon being prompted to regen answers NO....and so it does not
