Author Topic: This is too wierd!!  (Read 11705 times)
PDJ
Re: This is too wierd!!
« Reply #45 on: September 23, 2005, 05:31:39 PM »
Hey Dommy, I'm taking the blame off you.. The last time my pdj.lsp file was updated was back in May so unless a program can modify a file and change the date once it's done, I don't see it as being your file.  As for anyone knowing how to program, these are all telephone geeks.. They can program your phone to do strange things and that's about the extent of it.  I'm still using the xcr.vlx file and my RT routine so I'm not sweating it.. Well, I am sweating a little, dang heat is on for some reason..
OK, so let's all back off Dommy, it weren't his fault..
Thanks for the file Dommy, I've been using it like crazy the past few days.
Dommy2Hotty
« Reply #46 on: September 23, 2005, 06:00:14 PM »
Nothing to apologize for...never bothered me one bit...now, had something serious occured on your system...then I would have to drive to RescourceCAD's office and dish out the pain!  You didn't know I was a bodybuilder?
Dommy2Hotty
« Reply #47 on: September 23, 2005, 06:03:37 PM »
Security guy is checkin' out my caboose!
« Reply #48 on: September 23, 2005, 07:11:26 PM »
Wait a sec, I think Bob's got a word on this ...
Bob Wahr
« Reply #49 on: September 23, 2005, 07:14:06 PM »
Absolutely possible although I doubt it in this case.
Dommy, you and the security guard look good together.
MP, quick trying to be psychic.
Bob Wahr
« Reply #50 on: September 23, 2005, 07:45:17 PM »
Quick?????????
let's try "quit" instead.
« Reply #51 on: September 23, 2005, 07:47:53 PM »
Maybe you typed too quit.
 :lmao:
« Reply #52 on: September 23, 2005, 07:48:59 PM »
Made sense to me the first time too Bob .. I thought you were commenting on the speed of his psychicness <sp>
« Last Edit: September 23, 2005, 07:53:38 PM by Kerry Brown »
« Reply #53 on: September 23, 2005, 08:47:53 PM »
Rest assured that the XCR.vlx file did NOT modify anything on your computer ... It was likely a coincidence and you probably never noticed the message before. Anyway, as I said before ... no harm no foul ... I don't see hendie getting all bent of it being shared ...after all that is WHY it is there ... to be shared ... only RCI would prefer that users download their own files as it would prevent such from happening in the future ... (If you really want to know ... I am a founding member) now if you want to check the VLX to verify that someone has not modified it (I take it you have read the thread about the security of VLX and FAS files)
Simply download the file from RCI and do a binary file comparison i.e. at the command prompt ....
fc /b xcr1.vlx xcr2.vlxIf there are any discrepancies then you will know about it.
Food for thought ... it is quite possible and simple for a rogue VBA routine to put such in a file without modifying the time and date stamp of the file.
VerticalMojo
« Reply #54 on: September 26, 2005, 10:17:38 AM »
Well, I'm not one to point fingers...but....
I BLAME VERTICAL MOJO!
Hey! Where's my lawyer... :|
