Author Topic: I would like to create a custom distance  (Read 5684 times)
Re: I would like to create a custom distance
« Reply #15 on: November 12, 2007, 11:12:03 AM »
PS.  You get extra credit if you can figure out the two mistakes I made in my first post of the routine.
 :evil:
CECE_CAD
« Reply #16 on: November 12, 2007, 11:59:21 AM »
Ok, I will try that.  Thanks
CECE_CAD
« Reply #17 on: November 13, 2007, 04:25:25 PM »
ok lets see..
Thanks by the way.  I like how that works, the vlide
(grvecs (append vecs '(1)))  you changed the way the program returns the value..?  to this (grvecs (append '(1) vecs))
Then added the way the program closes with (princ).  Did you change (print) to (prompt) for consistency?
 :evil:
« Last Edit: November 13, 2007, 04:28:25 PM by CECE_CAD »
« Reply #18 on: November 13, 2007, 05:23:46 PM »
Good job. 8-)
The princ keeps nil or any other value from showing up at the command line when the routine finishes.
Yes the prompt was a change too as the number was not displaying properly.
As for grvecs, I had the color '(1) in the wrong place. It was displaying white when I wanted red.
