Author Topic: ssget filter  (Read 1910 times)
ssget filter
« on: July 18, 2007, 04:25:44 PM »
Does anyone see why this ss below would not filter polylines on one layer and blocks on one layer? Right now it is only selecting the blocks?
  (setq ss (ssget (list '(-4 . "OR<")
'(-4 . "<AND")
'(0 . "*POLYLINE")
(cons 8 *polylay*)
'(-4 . "AND>")
'(-4 . "<AND")
'(0 . "INSERT")
(cons 8 *entlay*)
'(-4 . "AND>")
'(-4 . "OR>")
« Last Edit: July 18, 2007, 04:26:55 PM by ronjonp »
deegeecees
Re: ssget filter
« Reply #1 on: July 18, 2007, 04:30:18 PM »
setq <add space> ss
Just a shot in the dark...
Jeff_M
  • C3D user & customizer
Re: ssget filter
« Reply #2 on: July 18, 2007, 04:33:26 PM »
"<OR"
Changing that worked for me.....
Make sure, too, that the *polylay* variable holds the desired layer.
« Last Edit: July 18, 2007, 04:36:27 PM by Jeff_M »
Re: ssget filter
« Reply #3 on: July 18, 2007, 04:35:13 PM »
Thanks Jeff....sometimes you need another set of eyes :)
