I have an attributed block that was created that uses the same tag name for multiple attributes. I need to be able to select say the second one and input the revision number, date, description, cad, chkd, and approved via a lisp.
and then i can edit that one to work for the 3rd row, 4th and so on as needed.
If the idiots that created this block wouldnt have just copied the text and actually gave it a individual value I would be ok.
