Author Topic: Launch Civil 3D XSL toolbox report from the command line  (Read 2295 times)
sdunn
« on: March 01, 2012, 12:58:30 PM »
I cannot find anywhere in the report source code where a command is created that starts the process.  Is it possible to launch an xsl based report from the command line or via code?
dgorsman
Re: Launch Civil 3D XSL toolbox report from the command line
« Reply #1 on: March 01, 2012, 06:11:17 PM »
XSL or XML?
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
sdunn
« Reply #2 on: March 02, 2012, 09:39:36 AM »
The General Legal Description for Parcels.  It is an XSL report.
« Reply #3 on: March 02, 2012, 09:47:43 AM »
I've looked for ways to do so, and tried numerous things, all without success. It would probably help if I knew how the XML/XSL files work together, but I haven't figured that out yet either (not that I've tried too hard, because looking at the code for these makes my head hurt :-) )
dgorsman
« Reply #4 on: March 02, 2012, 11:44:11 AM »
I'm not familiar with Civil3D, so they may be using XSL term as something else.  If they are using it for actual XSL, I might be able to help with that.
XML is a nice, structured data format using tagged elements.  XSL is an instructional language used to transform XML into other forms, whether its HTML, CSV, or a different arrangement of XML.  Typically what would happen is a program generates a report in XML, either as data or as as XML file.  If the XML is just data, the XSL can be applied to transform the content to a text stream which is written to a file (for example, HTML).  If the XML is saved to a file, then it can be read back in and transformed, or a pointer to the XSL file can be added to the XML header, which causes the stylesheet to be applied when the file is double-clicked.
In theory, if the program like Civil3D stores the XSL stylesheet separately you could customize report format by changing the XSL contents without touching the internal program structure.
Look here and here.
try {GreatPower;}
   finally
      {MasterBasics;}
sdunn
« Reply #5 on: March 05, 2012, 09:15:02 AM »
I can and have modified the style sheets and much of the java based code they contain.  I am after the mechanism that is used within Civil 3d to initiate the report process.
