Code Red => AutoLISP (Vanilla / Visual) => Topic started by: Peter2 on November 25, 2015, 06:17:13 AM
After a long pause I have to fight against DBX again :whistling:
I want to check all layers, which are used by objects in an objectlist, if they are "off" or "frozen". In Lisp I check if
- DXF-GC 70 contains "1" (frozen)
- DXF GC 62 is negative (off)
(foreach bild ObjLst
(setq bildlayer (cdr (assoc 8 (entget bild))))
; DXF-Code: 70 enthält 1 -> gefroren; 62 (Farbe) ist negativ -> ausgeschaltet
(setq bildlayer_dxf (tblsearch "layer" bildlayer))
(if (or
(= (logand 1 (cdr (assoc 70 bildlayer_dxf))) 1); wenn der GC 70 den Bitcode 1 = gefroren
(< (cdr (assoc 62 bildlayer_dxf)) 0) ; negativ -> ausgeschaltet
(setq layerflag 1)
Please help me to make it with DBX.
Thanks and regards
Peter;
You may need to explain this so it's understandable in the context of the code you posted.
(tblsearch) searches tables in the current document and can therefore not be use in an (O)DBX context.
Thanks Roy ... I'm blind as well as silly.
(setq item (vla-item (vla-get-layers doc) "LayerName"))
(equal (vla-get-freeze item) :vlax-true) ; returns t if layer is frozen
(equal (vla-get-layeron item) :vlax-true) ; returns t if layer is on
Sorry, Kerry. When I'm under pressure and I have the feeling that a "common dbx two-liner" will do the job but I don't have any clue - then my postings are not as precise as they should be :embarrassed:
Thanks - exactly the two-liner I hoped for. :yay!:
