Author Topic: How to create a Dimension on plan XZ or YZ ?  (Read 7329 times)
bikelink
« on: February 12, 2009, 12:38:37 PM »
I'm not able to build correctly an alingeddimension on plan xz.
It is always distant in y from the 2 original point .
I've tried to pass as argument  also the normal vector ..but isn't correct. the dimlinepoint is always distant in a dimension..
also if i set this to Xlinepoint1 or XlinePoint2..
AlignedDimension dim1 = new AlignedDimension();
                dim1.SetDatabaseDefaults();
                dim1.XLine1Point = duepunti.PuntoInizio;
                dim1.XLine2Point = duepunti.PuntoFine;
                dim1.DimLinePoint = PtLineaQuota;
                dim1.Normal = vnormal;
                dim1.DimensionText = testoquota;
                dim1.TextRotation = textrotation;
Thank you ...
Re: How to create a Dimension on plan XZ or YZ ?
« Reply #1 on: February 12, 2009, 04:51:38 PM »
how about this hack   :laugh:
namespace ExecMethod
  public static class Commands
    [CommandMethod("doit")]
    public static void doit()
      Editor ed = AcAp.Application.DocumentManager.MdiActiveDocument.Editor;
      try
        Point3d p1 = new Point3d(0, 0 ,0);
        Point3d p2 = new Point3d(100, 100,0);
        AlignedDimension Dim1 = CreateAlignedDimension(p1,p2,10.0);
        AlignedDimension Dim2 = CreateAlignedDimension(p1, p2, -10.0);
        Dim1.AddToModelSpace();
        Dim2.AddToModelSpace();
      catch (System.Exception ex)
        ed.WriteMessage(ex.Message);
        ed.WriteMessage(ex.StackTrace);
    internal static AlignedDimension CreateAlignedDimension(Point3d p1, Point3d p2, double offset)
      AlignedDimension dim = new AlignedDimension();
      dim.XLine1Point = p1;
      dim.XLine2Point = p2;
      using (Line line = new Line(p1, p2))
        using (Curve c = line.GetOffsetCurves(offset)[0] as Curve)
          dim.DimLinePoint = c.GetPointAtParameter(p1.DistanceTo(p2) / 2);
      return dim;
    internal static ObjectId AddToModelSpace(this Entity ent)
      ObjectId objId = ObjectId.Null;
      if (ent == null)
        throw new ArgumentNullException();
      Database Db = HostApplicationServices.WorkingDatabase;
      AcDb.TransactionManager Tm = Db.TransactionManager;
      using (Transaction tr = Tm.StartTransaction())
        BlockTable tb = (BlockTable)tr.GetObject
          (Db.BlockTableId, OpenMode.ForRead, false);
        objId = ((BlockTableRecord)tr.GetObject
          (tb[BlockTableRecord.ModelSpace], OpenMode.ForWrite, false)).AppendEntity(ent);
        tr.AddNewlyCreatedDBObject(ent, true);
        tr.Commit();
      return objId;
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
« Reply #2 on: February 12, 2009, 06:34:32 PM »
Daniel,
I saw 'Dim' in your code and almost had an accident. :)
ps
En route to Shanghai
Is there a DisneyWorld where you're going ?
Called Kerry in my other life
I live at UTC + 13.00
« Reply #3 on: February 12, 2009, 07:47:47 PM »
 :lol:
Unfortunately it’s not built yet  :|
bikelink
« Reply #4 on: February 13, 2009, 01:35:29 AM »
HI Daniel, thank you for your answer , but your code doesn't build a dimension on plan XZ...or yZ. The two dimensions are in the plan XY...
And I need to build dimensions in real 3d space.
« Reply #5 on: February 13, 2009, 07:45:15 AM »
Doh! Sorry  :oops:
bikelink
« Reply #6 on: February 14, 2009, 02:01:40 AM »
no one in the world..can help me?  :cry:
gile
  • Marseille, France
« Reply #7 on: February 14, 2009, 05:10:47 AM »
I'am not already comfortable with .NET, so I just edit Daniel's code using a 'TransformBy' way (maybe there's a shorter one).
I added a parameter to CreateAlignedDimension method: the plane where to create the dimension.
In this method, I transform points WCS coordinates to the plane coordinates (the transformed points must have a 0.0 Z coordinate).
After the dimension is created (as a 2d entity), I transfrom it back to WCS.
In the 'doit' method the planes are defined using  its normal vector and use one of the dimension point coordinate to build the origin (to get the plane elevation).
I had also some informations on command line about transformed points (note they all have a 0.0 Z coordinate)
using System;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            try
                Point3d p1 = new Point3d(0, 0, 0);
                Point3d p2 = new Point3d(0, 100, 100);
                // define the dimension plane: YZ plane, origin = 0,0,0
                Plane yzPlane = new Plane(p1, new Vector3d(1, 0, 0));
                Point3d p3 = new Point3d(10, 20, 30);
                Point3d p4 = new Point3d(60, 20, 50);
                // define the dimension plane: parallel to ZX plane, origin = 10,20,30, IOW elevation = 20
                Plane zxPlane = new Plane(p3, new Vector3d(0, -1, 0));
                AlignedDimension Dim1 = CreateAlignedDimension(p1, p2, 10.0, yzPlane);
                AlignedDimension Dim2 = CreateAlignedDimension(p3, p4, 10.0, zxPlane);
                ed.WriteMessage("p1 = {0}\n", p1.TransformBy(Matrix3d.WorldToPlane(yzPlane)));
                ed.WriteMessage("p2 = {0}\n", p2.TransformBy(Matrix3d.WorldToPlane(yzPlane)));
                ed.WriteMessage("p3 = {0}\n", p3.TransformBy(Matrix3d.WorldToPlane(zxPlane)));
                ed.WriteMessage("p4 = {0}\n", p4.TransformBy(Matrix3d.WorldToPlane(zxPlane)));
        internal static AlignedDimension CreateAlignedDimension(Point3d p1, Point3d p2, double offset, Plane plane)
            // Transform WCS points to plane
            p1 = p1.TransformBy(Matrix3d.WorldToPlane(plane));
            p2 = p2.TransformBy(Matrix3d.WorldToPlane(plane));
            // return transformed Dimension to WCS
            dim.TransformBy(Matrix3d.PlaneToWorld(plane));
            return dim;
            if (ent == null)
            Autodesk.AutoCAD.DatabaseServices.TransactionManager Tm = Db.TransactionManager;
                tr.Commit();
            return objId;
« Last Edit: February 14, 2009, 06:08:49 AM by gile »
bikelink
« Reply #8 on: February 14, 2009, 06:35:11 AM »
Amazing gile ! I haven't words to say how much precious this suggest was for me!
Thank You very very much!
I would not have ever been able to made this on my own!
gile
  • Marseille, France
« Reply #9 on: February 14, 2009, 07:56:55 AM »
You're welcome, I'm learning too...
As I thaught, there's a simpler way, just using the plane Normal and use The Elevation property of the Dimension class. The dimension elevation is gotten with the Z coordinate of a transformed point.
using System;
            try
                // YZ plane normal
                Vector3d yzNormal = new Vector3d(1, 0, 0);
                // ZX plane normal
                Vector3d zxNormal = new Vector3d(0, -1, 0);
                AlignedDimension Dim1 = CreateAlignedDimension(p1, p2, 10.0, yzNormal);
                AlignedDimension Dim2 = CreateAlignedDimension(p3, p4, 10.0, zxNormal);
                ed.WriteMessage("Transformed p1 = {0}\n", p1.TransformBy(Matrix3d.WorldToPlane(yzNormal)));
                ed.WriteMessage("Transformed p2 = {0}\n", p2.TransformBy(Matrix3d.WorldToPlane(yzNormal)));
                ed.WriteMessage("Transformed p3 = {0}\n", p3.TransformBy(Matrix3d.WorldToPlane(zxNormal)));
                ed.WriteMessage("Transformed p4 = {0}\n", p4.TransformBy(Matrix3d.WorldToPlane(zxNormal)));
        internal static AlignedDimension CreateAlignedDimension(Point3d p1, Point3d p2, double offset, Vector3d normal)
            p1 = p1.TransformBy(Matrix3d.WorldToPlane(normal));
            p2 = p2.TransformBy(Matrix3d.WorldToPlane(normal));
            dim.TransformBy(Matrix3d.PlaneToWorld(normal));
            dim.Elevation = p1.Z;
            return dim;
            if (ent == null)
                tr.Commit();
            return objId;
« Reply #10 on: February 14, 2009, 08:24:25 AM »
Nice Work Gile  8-)
gile
  • Marseille, France
« Reply #11 on: February 14, 2009, 08:34:33 AM »
Thanks Daniel, you did most of the work.
I just played a little with transfomations...
bikelink
« Reply #12 on: February 17, 2009, 03:04:36 AM »
of course also the help from Daniel was precious.. but the dimension on plan xy was already able to make it.
James Cannon
« Reply #13 on: February 17, 2009, 08:17:29 AM »
This may be a dumb question, but why can't you just change your UCS dynamically and avoid the overhead of programmatic solutions altogether?
« Reply #14 on: February 17, 2009, 08:36:47 AM »
With all due respect, on this forum that's akin to asking a skier "why bother skiing down a hill when there's a perfectly good gondola?". :)
