Author Topic: strange problem with events  (Read 7283 times)
sybold
« on: February 26, 2013, 05:55:30 AM »
i have a save handler problem, on loading it works, on opening a drawing it works.
but after a while it's gone and it doesn't work anymore.
it saves same attribute values to a sql server
the sql part works, also from a button on the ribbon, but i like to make it work on every save event.
my code:
Code - vb.net: [Select]
  1. Imports System
  2. Imports Autodesk.AutoCAD.Runtime
  3. Imports Autodesk.AutoCAD.ApplicationServices
  4. Imports Autodesk.AutoCAD.DatabaseServices
  5. Imports Autodesk.AutoCAD.Geometry
  6. Imports Autodesk.AutoCAD.EditorInput
  7. Imports System.IO
  8.
  9.
  10. <Assembly: ExtensionApplication(GetType(savehandler_2013.MyPlugin))>
  11.
  12. Namespace savehandler_2013
  13.
  14.     Public Class MyPlugin
  15.         Implements IExtensionApplication
  16.         Private _DocumentManager As DocumentCollection
  17.         Private Shared _Controllers As Dictionary(Of Document, PerDocController)
  18.         Public Sub Initialize() Implements IExtensionApplication.Initialize
  19.             '#### document controller ####
  20.             _DocumentManager = Application.DocumentManager
  21.             _Controllers = New Dictionary(Of Document, PerDocController)
  22.
  23.             For Each document As Document In _DocumentManager
  24.                 _Controllers.Add(document, New PerDocController(document))
  25.             Next
  26.             AddHandler _DocumentManager.DocumentActivated, AddressOf DocumentActivated
  27.             AddHandler _DocumentManager.DocumentCreated, AddressOf DocumentCreated
  28.             AddHandler _DocumentManager.DocumentToBeDestroyed, AddressOf DocumentToBeDestroyed
  29.         End Sub
  30.
  31.         Public Sub Terminate() Implements IExtensionApplication.Terminate
  32.             RemoveHandler _DocumentManager.DocumentActivated, AddressOf DocumentActivated
  33.             RemoveHandler _DocumentManager.DocumentCreated, AddressOf DocumentCreated
  34.             RemoveHandler _DocumentManager.DocumentToBeDestroyed, AddressOf DocumentToBeDestroyed
  35.         End Sub
  36.
  37.         Private Sub DocumentActivated(sender As Object, e As DocumentCollectionEventArgs)
  38.             If Not (_Controllers.ContainsKey(e.Document)) Then
  39.                 _Controllers.Add(e.Document, New PerDocController(e.Document))
  40.                 e.Document.Editor.WriteMessage(vbCrLf + " - Document Activated! ")
  41.             End If
  42.
  43.         End Sub
  44.         Private Sub DocumentToBeDestroyed(sender As Object, e As DocumentCollectionEventArgs)
  45.             If (_Controllers.ContainsKey(e.Document)) Then
  46.                 _Controllers(e.Document).Destroy()
  47.                 _Controllers.Remove(e.Document)
  48.             End If
  49.         End Sub
  50.         Private Sub DocumentCreated(sender As Object, e As DocumentCollectionEventArgs)
  51.             If Not (_Controllers.ContainsKey(e.Document)) Then
  52.                 _Controllers.Add(e.Document, New PerDocController(e.Document))
  53.                 e.Document.Editor.WriteMessage(vbCrLf + " - Document Created! ")
  54.             End If
  55.         End Sub
  56.
  57.     End Class
  58.     Public Class PerDocController
  59.         Private _Document As Document
  60.         Public Sub New(ByVal document As Document)
  61.             _Document = document
  62.             If Not Getblockid("sqldataholder") = ObjectId.Null Then
  63.                 AddHandler _Document.Database.BeginSave, AddressOf BeginSave
  64.                 AddHandler _Document.Database.SaveComplete, AddressOf SaveComplete
  65.                 _Document.Editor.WriteMessage(vbCrLf + " - Savehandler Added! ")
  66.             End If
  67.         End Sub
  68.
  69.         Public Sub Destroy()
  70.             RemoveHandler _Document.Database.BeginSave, AddressOf BeginSave
  71.             RemoveHandler _Document.Database.SaveComplete, AddressOf SaveComplete
  72.         End Sub
  73.
  74.         Function Getblockid(ByVal blockName As String) As ObjectId
  75.             Dim RetBlkId As ObjectId = ObjectId.Null
  76.             Dim doc As Document = Application.DocumentManager.MdiActiveDocument
  77.             Dim db As Database = doc.Database
  78.             Dim ed As Editor = doc.Editor
  79.             Try
  80.                 Using tr As Transaction = db.TransactionManager.StartTransaction
  81.                     Dim bt As BlockTable = db.BlockTableId.GetObject(OpenMode.ForRead)
  82.                     Dim btr As BlockTableRecord = bt(blockName).GetObject(OpenMode.ForRead)
  83.                     Dim brefCount As Integer = 0
  84.                     For Each objId As ObjectId In btr.GetBlockReferenceIds(True, True)
  85.                         brefCount = btr.GetBlockReferenceIds(True, True).Count
  86.                         If brefCount > 1 Then
  87.                             ed.WriteMessage(vbCrLf & " - mutiple blocks found, check drawing!")
  88.                             Exit Function
  89.                         ElseIf brefCount = 0 Then
  90.                             ed.WriteMessage(vbCrLf & " - Block, " & blockName & " not found on screen")
  91.                             Exit Function
  92.                         Else
  93.                             Dim ent As Entity = objId.GetObject(OpenMode.ForRead)
  94.                             RetBlkId = ent.ObjectId
  95.                         End If
  96.                     Next
  97.                 End Using
  98.             Catch ex As Autodesk.AutoCAD.Runtime.Exception
  99.                 ed.WriteMessage(vbCrLf & " - Block, " & blockName & " not found")
  100.             End Try
  101.             Return RetBlkId
  102.         End Function
  103.
  104.         Sub SetAttribute(ByVal blockId As ObjectId, ByVal attTag As String, ByVal attVal As String)
  105.             Dim doc As Document = Application.DocumentManager.MdiActiveDocument
  106.             Dim db As Database = doc.Database
  107.             Dim ed As Editor = doc.Editor
  108.             Try
  109.                 Using tr As Transaction = db.TransactionManager.StartTransaction
  110.                     Dim br As BlockReference
  111.                     Dim ac As AttributeCollection
  112.                     br = blockId.GetObject(OpenMode.ForWrite)
  113.                     ac = br.AttributeCollection
  114.                     Dim ent As ObjectId
  115.                     Dim ar As AttributeReference
  116.                     For Each ent In ac
  117.                         ar = ent.GetObject(OpenMode.ForWrite)
  118.                         If String.Compare(ar.Tag.ToUpper, attTag.ToUpper, True) = 0 Then
  119.                             ar.TextString = attVal
  120.                         End If
  121.                     Next
  122.                     tr.Commit()
  123.                     tr.Dispose()
  124.                 End Using
  125.             Catch ex As Autodesk.AutoCAD.Runtime.Exception
  126.                 ed.WriteMessage(vbCrLf & "Error: {0}" & vbCrLf & "Stack trace: {1}", ex.Message, ex.StackTrace)
  127.             End Try
  128.         End Sub
  129.
  130.
  131.         Private Sub BeginSave(sender As Object, e As DatabaseIOEventArgs)
  132.             _Document.Editor.WriteMessage(vbCrLf + " - Begin Save! ")
  133.
  134.             If Not Getblockid("sqldataholder") = ObjectId.Null Then
  135.                 _Document.Editor.WriteMessage(vbCrLf + " - step 1! ")
  136.                 Try
  137.                     SetCustomProperty("sql", "true")
  138.                 Catch ex As Autodesk.AutoCAD.Runtime.Exception
  139.                     _Document.Editor.WriteMessage(vbCrLf & "Error: {0}" & vbCrLf & "Stack trace: {1}", ex.Message, ex.StackTrace)
  140.                 End Try
  141.                 _Document.Editor.WriteMessage(vbCrLf + " - step 2! ")
  142.                 Try
  143.                     SetCustomProperty("user", Environ$("USERNAME"))
  144.                 Catch ex As Autodesk.AutoCAD.Runtime.Exception
  145.                     _Document.Editor.WriteMessage(vbCrLf & "Error: {0}" & vbCrLf & "Stack trace: {1}", ex.Message, ex.StackTrace)
  146.                 End Try
  147.                 _Document.Editor.WriteMessage(vbCrLf + " - step 3! ")
  148.                 Try
  149.                     SetCustomProperty("DATEUPD", Format(Date.Now, "dd-MM-yy"))
  150.                 Catch ex As Autodesk.AutoCAD.Runtime.Exception
  151.                     _Document.Editor.WriteMessage(vbCrLf & "Error: {0}" & vbCrLf & "Stack trace: {1}", ex.Message, ex.StackTrace)
  152.                 End Try
  153.                 _Document.Editor.WriteMessage(vbCrLf + " - step 4! ")
  154.                 Try
  155.                     SetAttribute(Getblockid("testblock"), "tag", "value")
  156.                 Catch ex As Autodesk.AutoCAD.Runtime.Exception
  157.                     _Document.Editor.WriteMessage(vbCrLf & "Error: {0}" & vbCrLf & "Stack trace: {1}", ex.Message, ex.StackTrace)
  158.                 End Try
  159.             End If
  160.             '' send block data to sql db.
  161.             'sendtosqldb("sqldataholder")
  162.
  163.             Dim w As StreamWriter = File.AppendText("c:\temp\savehandlerlog.txt")
  164.             logger(_Document.Name, w)
  165.             w.Close()
  166.
  167.         End Sub
  168.
  169.         Private Sub SaveComplete(sender As Object, e As DatabaseIOEventArgs)
  170.             _Document.Editor.WriteMessage(vbCrLf + " - Save Complete! ")
  171.
  172.         End Sub
  173.         Private Sub logger(ByVal logMessage As String, ByVal w As TextWriter)
  174.             w.Write(ControlChars.CrLf & "Log Entry : ")
  175.             w.WriteLine("{0} {1}", DateTime.Now.ToLongTimeString(), DateTime.Now.ToLongDateString())
  176.             w.WriteLine("  :")
  177.             w.WriteLine("  :{0}", logMessage)
  178.             w.WriteLine("-------------------------------")
  179.             ' Update the underlying file.
  180.             w.Flush()
  181.         End Sub
  182.         Sub SetCustomProperty(ByVal Name As String, ByVal Value As String)
  183.             Dim doc As Document = Application.DocumentManager.MdiActiveDocument
  184.             Dim db As Database = doc.Database
  185.             Dim ed As Editor = doc.Editor
  186.             Dim Builder As DatabaseSummaryInfoBuilder = New DatabaseSummaryInfoBuilder(db.SummaryInfo)
  187.
  188.             If Builder.CustomPropertyTable.Contains(Name) Then
  189.                 Builder.CustomPropertyTable.Item(Name) = Value
  190.             Else
  191.                 Builder.CustomPropertyTable.Add(Name, Value)
  192.             End If
  193.
  194.             db.SummaryInfo = Builder.ToDatabaseSummaryInfo
  195.         End Sub
  196.     End Class
  197. End Namespace
« Last Edit: February 26, 2013, 01:09:36 PM by sybold »
BlackBox
Re: strange problem with events
« Reply #1 on: February 26, 2013, 09:32:13 AM »
Quickly written example:
Code - C#: [Select]
  1.
  2. using Autodesk.AutoCAD.ApplicationServices;
  3. using Autodesk.AutoCAD.DatabaseServices;
  4. using Autodesk.AutoCAD.EditorInput;
  5. using Autodesk.AutoCAD.Runtime;
  6.
  7. using acApp = Autodesk.AutoCAD.ApplicationServices.Application;
  8.
  9. [assembly: ExtensionApplication(typeof(TheSwamp.Sample.Events.Save))]
  10.
  11. namespace TheSwamp.Sample.Events
  12. {
  13.     public class Save : IExtensionApplication
  14.     {
  15.         public void Initialize()
  16.         {
  17.             DocumentCollection acDocs = acApp.DocumentManager;
  18.             Document doc = acDocs.MdiActiveDocument;
  19.             Editor ed = doc.Editor;
  20.
  21.             acDocs.DocumentCreated += OnDocumentCreated;
  22.             doc.CommandWillStart += OnCommandWillStart;
  23.         }
  24.
  25.         public void Terminate()
  26.         {
  27.         }
  28.
  29.         public void BowtiesAreCool() //<-- Change this to something useful
  30.         {
  31.             acApp.DocumentManager.MdiActiveDocument.Editor.WriteMessage(
  32.                 "\n** Bowties are cool ** \n"
  33.             );
  34.         }
  35.
  36.         void OnCommandWillStart(object sender, CommandEventArgs e)
  37.         {
  38.             if (e.GlobalCommandName.ToUpper().Contains("SAVE"))
  39.                 BowtiesAreCool(); //<-- Change this to something useful
  40.         }
  41.
  42.         void OnDocumentCreated(object sender, DocumentCollectionEventArgs e)
  43.         {
  44.             if (e.Document != null)
  45.                 e.Document.CommandWillStart += OnCommandWillStart;
  46.         }
  47.     }
  48. }
  49.
sybold
« Reply #2 on: February 26, 2013, 11:08:36 AM »
that's another way how to do it.
in 2012 it works without a problem, in 2013 it works for a limited time.
we found this problem after upgrading a few workstations to 2013 to test, if it all worked as needed.
The save begin handle doesn't function anymore after some point, i can't figure out why and when.
BlackBox
« Reply #3 on: February 26, 2013, 12:54:48 PM »
If the command Event handler is registered successfully, I do not understand how it would stop working prior to the Document being removed from the Document Collection... That suggests it's being unregistered AFAIK.
Silly question, but you don't by chance have multiple plug-ins with the same Method name for your command event handler do you? Perhaps one of those would-be variants is being unregistered?
I would assume not, but I thought I'd ask... Perhaps a more knowledgeable member can step in, and educate us both.
sybold
« Reply #4 on: February 26, 2013, 01:09:03 PM »
it's weird, this is the only plugin currently running on the dev/test machine.
maybe there is a way to visualy check if the handler is added,active or removed.
BlackBox
« Reply #5 on: February 26, 2013, 01:15:08 PM »
What happens when you step through the code in debug?
BlackBox
« Reply #6 on: February 26, 2013, 01:16:15 PM »
Note - I would use a minimal framework version (such as what i posted) first, then begin adding more complexity to your plug-in incrementally to see where the breakdown occurs.
kaefer
« Reply #7 on: February 26, 2013, 02:29:11 PM »
Don't you all think that it's a little bit preposterous to expect AutoCAD doing all this heavy lifting inside an event handler without demurring?
Please somebody confirm my suspicion that it's generally not the best idea to do computationally intensive operations on borrowed time. Reading around this place, I've come to the impression that even the command ended and quiescent state events could prove troublesome in that regard.
TheMaster
« Reply #8 on: February 26, 2013, 05:29:28 PM »
Per chance, are there 3D solids involved?
« Reply #9 on: February 26, 2013, 05:34:14 PM »
Wow, that's a question really skirting the edges of the problem !!
I assume it's experience based ; or are you psychic, Tony ? :)
BlackBox
« Reply #10 on: February 26, 2013, 05:38:17 PM »
Couldn't say, as I didn't even bother to look at the 'heavy lifting' being performed... The OP couldn't get the Save reactor to fire as expected, so I simply thought I'd start there.
TheMaster
« Reply #11 on: February 26, 2013, 05:38:33 PM »
There are limitations on what you can do inside event handlers, but generally what point would there be in notifying you about something, if you can't act on it? In some cases, you can simply set a flag and check it at some later point, and if set, do the heavy lifting, but in the case of saving a file, you really don't have a choice if the work you need to do is supposed to be saved with the drawing that's about to be written.
Event handlers can bog down AutoCAD if they are doing a lot of work, and the events fire frequently. The ones you cite (Command-related and Quiescent state-related) could fire frequently only under scripting (for example, a LISP script that executes one or more commands many times in a loop), but in non-scripting scenarios, those events are not fired often since there is usually user-interaction involved. However, because scripting is most-likely in use, one should consider the command-related events as high-frequency events for all intents and purposes.
The really 'high-frequency' events are usually the ones that notify you about events at the object-level, like the ObjectModified/Erased/Appended events of the Database. The Application's Idle event is another one that can fire often (on every mouse move and keypress), which is why it's a good idea to avoid doing a lot of work every time that event fires.
« Last Edit: February 26, 2013, 05:42:22 PM by TT »
TheMaster
« Reply #12 on: February 26, 2013, 05:46:17 PM »
AutoCAD 2013 introduces local caching of 3D graphics, which (obviously) must happen when a file is saved :wink:
BlackBox
« Reply #13 on: February 26, 2013, 05:54:12 PM »
Thanks Keafer for posing the question, and Tony for the clarification... Seemed very commonsensical having read your response, but always helpful/educational.
Cheers :beer:
sybold
« Reply #14 on: March 04, 2013, 02:53:14 PM »
after some day's of testing. I've came to a couple of things.
autocad 2009, no problems all works like it should.
autocad 2010, 2011, 2012 no problems all works like it should.
2013 works, until 1 document hits an autosave and the savehandlers are gone.
i know events have limitations, but it has been working for the last 5 years, why did it break in 2013.
the code hasn't changed much between the autocad versions.
Remember that this is not a full database app, i'm only doing a insert or update query to a sql database with 8 block attribute values.
there is no timing issue, or network delay.
i hope a fix is available, otherwise we will stay on 2012.
