Mtext Word wrap removal
Biscuits:
I'm looking for a routine/macro to remove word wrap on existing mtext without all the properties changing in the mtext dialogue box. Looking for a system variable change, lisp or VBA. It can be global or through a single selection. Does anyone have any ideas?
Using ACAD2002 on Windows 2000. Thanks
Mark:
Not perfect! Might fall down if you have a lot of formatting in your MTEXT.
--- Code: ---
(defun c:blastReturns (/ rm-returns ent entlst str new_str)
(defun rm-returns (str)
(while (wcmatch str "*\\P*")
(setq str (vl-string-subst " " "\\P" str))
str
(if (setq ent (car (entsel "\nSelect MTEXT: ")))
(setq entlst (entget ent)
str (cdr (assoc 1 entlst))
new_str (rm-returns str)
(setq entlst
(subst (cons 1 new_str) (assoc 1 entlst) entlst)
(entmod entlst)
--- End code ---
Mark:
Newer version, more error checking.
--- Code: ---
str
(setq entlst (entget ent))
(if (= (cdr (assoc 0 entlst)) "MTEXT")
(setq str (cdr (assoc 1 entlst))
entlst (subst (cons 1 new_str) (assoc 1 entlst) entlst)
(entmod entlst)
); progn
(princ "\nThat wasn't MTEXT was it!!")
); if
--- End code ---
Jeff_M:
While Mark's removes hard returns in Mtext, I understood that Biscuit wanted to remove the auto word wrap when the text doesn't fit all on one line. The following does that.
--- Code: ---
(defun c:nowrap (/ doc ss)
(setq doc (vla-get-activedocument (vlax-get-acad-object)))
(if (ssget '((0 . "MTEXT")))
(setq ss (vla-get-activeselectionset doc))
(vlax-for ent ss
(vla-put-width ent 0)
--- End code ---
Biscuits:
Thank you. I really appreciate the effort but what I need to accomplish is to change the mtext width property to (no wrap) on existing mtext. I'm not code-literate enough to understand what your routine does, but it doesn't change this property value.
Navigation
[0] Message Index
[#] Next page
Go to full version
