Author Topic: how to load a dll into AutoCAD from http or ftp  (Read 8060 times)
michiel
« on: March 01, 2012, 11:38:57 AM »
How can I load a dll that is not on the local disk? with http or ftp?
Thx
David Hall
  • Automatic Duh Generator
Re: how to load a dll into AutoCAD from http or ftp
« Reply #1 on: March 01, 2012, 11:56:44 AM »
Where is it located? if its on the network you load it the same way, with 'Netload'.  I dont think you can load from the internet
michiel
« Reply #2 on: March 01, 2012, 11:59:55 AM »
its located on the internet...
dgorsman
« Reply #3 on: March 01, 2012, 12:15:52 PM »
Badbadbadbadbadbadbadbad... there's a reason thats blocked from happening!   :police:
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
michiel
« Reply #4 on: March 01, 2012, 12:33:20 PM »
it's my own dll, that I want to share for other people, but not physically give the dll
n.yuan
« Reply #5 on: March 01, 2012, 03:02:31 PM »
You need to write code (or find some existing code somewhere) according to the protocol used (http or ftp) to download the DLL file to the CAD computer and save it somewhere in the local drive and then "netload" it. Downloading DLL/EXE is usually considered unsafe. So, the DLL file may have to be zipped up first. In this case, you need to Download->Save->Unzip->NETLOAD.
But do you want user to repeatedly download it from a remote http/ftp server whenevr they run AutoCAD? Or, what you actaully want to do is some kind of auto-update (similar to .NET ClickOnce)? In this case, you'd better kick off a separate updater app (or separate thread) that go the the http/ftp location to check available update/new version, and if found, download to temp. local location, and then prompt user in Acad. Once user choose to update, the updater app will update the local DLLs after Acad shut down, and then restart AutoCAD. It sound easier than actually doing it.
BlackBox
« Reply #6 on: March 01, 2012, 03:49:31 PM »
Perhaps this old post can be of use.
michiel
« Reply #7 on: March 02, 2012, 04:00:31 AM »
I have my file located on the internet(http or ftp doesnt matter) and I want to load de dll file in AutoCAD when the user have permission for working with the dll, but the users don't may have the dll file downloaded on there computer.
A loaded dll in AutoCAD is protected by windows to copy these files?
TheMaster
« Reply #8 on: March 02, 2012, 08:34:02 AM »
Actually, if you look at the Assembly.Load overloads you'll note that there
are a few that take byte[] as an argument, rather than a filename.
so.............  :roll:
TheMaster
« Reply #9 on: March 02, 2012, 08:35:19 AM »
Thx
An assembly can be loaded from an array of byte[] in memory.
MexicanCustard
« Reply #10 on: March 02, 2012, 08:44:54 AM »
***WARNING - THIS IS HIGHLY DANGEROUS FOR THE AUTOCAD USER AND WILL ALLOW ACCESS TO A DLL FROM ANYWHERE AND FROM ANYONE ***
Add the line  <loadFromRemoteSources enabled="true" /> to the <runtime> element of Acad.exe.config. Then you can netload it from any location you can browse to.
I don't know why you wouldn't let the user copy the DLL local, that makes no sense to me.  We use this option because I keep the DLLs on a network drive so I dont have to update 30 computers everytime I make a change to a utility.
« Last Edit: March 02, 2012, 08:48:53 AM by MexicanCustard »
n.yuan
« Reply #11 on: March 02, 2012, 12:45:36 PM »
<loadFromRemoteSources enabled="true" /> only useful if you force Acad to use .NET 4.0, which is only officially supported by Acad2012. With acad2010/11, forcing Acad to use .NET4.0 may have issues, I have heard.
michiel
« Reply #12 on: March 03, 2012, 04:36:28 AM »
Thx guys it works.
now I just have the problem that the dll is stored on the local computer in some directory of windows, but I can't find it, because when I load the dll from internet, it works fine the first time, I shut down my internet connection, and then I startup my program again, from the internet source and it still works...
Where is it stored? c:\windows\assembly ? C:\Windows\Microsoft.NET\assembly?
Is it possible to just load the dll in the instances of AutoCAD and is protected?
waterharbin
« Reply #13 on: March 04, 2012, 03:20:54 AM »
Hi,michiel. I want to do the same stuff. Can you just share your way?
michiel
« Reply #14 on: March 05, 2012, 04:52:19 AM »
1. Add the line  <loadFromRemoteSources enabled="true" /> to the <runtime> element of Acad.exe.config. Then you can netload it from any location you can browse to.
2. Make a new Classlibrary:
[CommandMethod("yourCommand")]
static public void MyNetLoad()
 try
        Assembly.LoadFrom(@"http://your network path here");
 }catch(){
3. debug, netload the new dll in AutoCAD, enter your command, and normally you can enter the command of the dll which you loaded from the internet
