Detect autocad express tools installed
(1/3) > >>
RAIN CODE:
Hi guys,
Just wondering - can autolisp able to detect if AutoCad Express Tools is installed ??
CAB:
     ;; Set Express Tools Flag
     (if (vl-catch-all-error-p (vl-catch-all-apply '(lambda()(acet-sys-shift-down))))
       (alert "\n** ExpressTools not loaded. Some Functions May not be Available. **")
       (setq shiftOK T)
Lee Mac:
Something similar:
--- Code - Auto/Visual Lisp: ---(defun expresstools-p nil    (or (member "acetutil.arx" (arx))        (and (findfile "acetutil.arx") (arxload "acetutil.arx" nil))    )    (eval        (list 'defun 'expresstools-p nil            (not                (vl-catch-all-error-p                    (vl-catch-all-apply                        (function (lambda nil (acet-sys-shift-down)))                    )                )            )        )    )    (expresstools-p))
MP:
While Lee's expresstools-p is cleverly penned (as usual :)) it captures and subsequently reports a static snapshot of the acet call attempt for the dynamically defined version of self, which sports misleading results if the ET tools library is unloaded (arxunload "acetutil.arx") after expresstools-p has been called:
(expresstools-p)
T
(expresstools-p)
T
*kaboom*
This can be remedied by modifying expresstools-p thusly:
--- Code: ---(defun expresstools-p nil
   (eval
          '(not
                   (vl-catch-all-apply
   (expresstools-p)
--- End code ---
That said, it still is not ideal, as expresstools-p will no longer make the attempt to load the ET library if the ET library is unloaded after it is called, merely returning nil:
(expresstools-p)
T
(expresstools-p)
nil
So in the end, my sleep deprived brain thinks the more pragmatic albeit less sexy version merely need be:
--- Code: ---(defun expresstools-p ( )
    (or
--- End code ---
But mommy, I need coffees. Bad.
Lee Mac:
You raise a good point MP, I hadn't considered the possibility of the Express Tools being unloaded.  :-)
Navigation
[0] Message Index
[#] Next page
Go to full version
