Author Topic: how to create sld file in silent mode  (Read 2686 times)
Sam
« on: March 20, 2012, 02:35:38 AM »
dear all
today's my 2nd question
how to create sld file in silent mode without open any drawing (it's possible)
because so many files
Every time we waste electricity, we put our planet's future in the dark. Let's turn around our attiude and start saving power and our planet, before it's too late
http://www.theswamp.org/donate.html
Re: how to create sld file in silent mode
« Reply #1 on: March 20, 2012, 02:58:14 AM »
Can't be done.
Try a script using something like ScriptPro.
Regards.
« Reply #2 on: March 20, 2012, 03:13:37 PM »
And here is a small/simple script for you to use with ScriptPro.
  1. ( (lambda ( / )
  2.     (mapcar
  3.       '(lambda ( x / )
  4.          (eval x)
  5.          (repeat 2 (command))
  6.          (princ))
  7.       '(
  8.         (command "_zoom" "e")
  9.         (command "_zoom" "0.9x")
  10.
  11.         (command "_mslide" (cadr (fnsplitl (getvar "DWGNAME"))))
  12.
  13.         (repeat 2 (command))
  14.
  15.         (command "_qsave")
  16.         ;; save
  17.         (command "_close")
  18.         ;; close
  19.         )
  20.       )
  21.     (princ)
  22.     )
  23.  )
Sam
« Reply #3 on: March 21, 2012, 05:49:22 AM »
  1. ( (lambda ( / )
  2.     (mapcar
  3.       '(lambda ( x / )
  4.          (eval x)
  6.          (princ))
  7.       '(
  10.
  12.
  14.
  16.         ;; save
  18.         ;; close
  19.         )
  20.       )
  21.     (princ)
  22.     )
  23.  )
dear sir
thx very much
Sam
« Reply #4 on: March 21, 2012, 05:51:35 AM »
dear all
found the lisp but very slow
  1. ;;the By carrot1983
  2. (defun C:DWG2SLD (/ ACADOBJ DOC DWG_DIR DWG_LST NAME SDI)
  3.   ;;By carrot1983
  4.   (defun CJW-FILE-GET (MSG / WINSHELL SHFOLDER PATH CATCHIT)
  5.     (setq WINSHELL (vlax-create-object "Shell.Application"))
  6.     (setq
  7.       SHFOLDER (vlax-invoke-method WINSHELL 'BROWSEFORFOLDER 0 MSG 1)
  8.     )
  9.     (setq
  10.       CATCHIT (vl-catch-all-apply
  11.                 '(lambda ()
  12.                    (setq SHFOLDER (vlax-get-property SHFOLDER 'SELF))
  13.                    (setq PATH (vlax-get-property SHFOLDER 'PATH))
  14.                  )
  15.               )
  16.     )
  17.     (if        (vl-catch-all-error-p CATCHIT)
  18.       NIL
  19.       PATH
  20.     )
  21.   )
  22.   (princ
  23.     "\nCAD graphical DWG files batch converted into a slide (DWGTOSLD) By carrot1983 2009-05-10"
  24.   )
  25.   (setvar "CMDECHO" 0)
  26.   (alert "\nNote: backup original!")
  27.   (if (and (setq DWG_DIR (CJW-FILE-GET "to select the DWG file folder?"))
  28.            (setq DWG_LST (vl-directory-files DWG_DIR "*.DWG" 1))
  29.       )
  30.     (progn
  31.       (foreach DWG DWG_LST
  32.         (if (setq SS (ssget "x"))
  33.           (command "._ERASE" SS "")
  34.         )
  35.         (setq DWG (strcat DWG_DIR "\\" DWG))
  36.         (setq SLD (strcat DWG_DIR "\\" (vl-filename-base DWG) ".sld"))
  37.         (command ".-INSERT" DWG "_NON" '(0. 0. 0.) "1" "1" "0")
  38.         (command "._ZOOM" "_E")
  39.         (command "._MSLIDE" SLD)
  40.         (print SLD)
  41.       )
  42.       (alert "program the finished <DWG2SLD>")
  43.       (command "._BROWSER" "http://carrot1983.blog.sohu.com/")
  44.     )
  45.   )
  46.   (princ)
  47. )
