Author Topic: dline setting?  (Read 1525 times)
craigr
dline setting?
« on: March 02, 2006, 12:18:58 PM »
I can't find the setting for dline that keeps it 'running'.
It is 'running' as long as I don't go over any other lines. If I do go over another line, the 'running' stops.
I've gone thru the settings that it offers on the command line, when you give the dLine command, none seem to change this.
I couldn't find anything that addressses this in the help file.
Is there such a setting?
craigr
whdjr
Re: dline setting?
« Reply #1 on: March 02, 2006, 12:53:47 PM »
What is dline, craigr?
craigr
Re: dline setting?
« Reply #2 on: March 02, 2006, 02:05:09 PM »
It makes a 'double line'.
One could use it to make the walls of a floor plan or ?
I thought all AutoCad versions had it (?).
craigr
whdjr
Re: dline setting?
« Reply #3 on: March 02, 2006, 02:13:53 PM »
I have Mline (multi-line) but not dline.   :-(
LE
Re: dline setting?
« Reply #4 on: March 02, 2006, 02:14:57 PM »
That routine was part of earlier versions of autocad... I forgot on what version came up...
craigr
Re: dline setting?
« Reply #5 on: March 02, 2006, 02:17:26 PM »
It's still part of LT2005. I hope they don't decide to dump it.
craigr
Re: dline setting?
« Reply #6 on: March 02, 2006, 05:38:14 PM »
I have a dline lisp routine. I thought it was part of express tools.
