OK, admittedly it's been a while since I did any 3D work and then it was done using LDT '04 so I'm just a little rusty. How does one create points along a feature line so that the points get their elevation from the line? I'm using the 'measure object' command to create points at 10' intervals along a feature line but they all have an elevation of 0.00.HELP!
Is the feature line used as surface data?
Quote from: Mark Thomas on February 12, 2009, 11:25:50 AMOK, admittedly it's been a while since I did any 3D work and then it was done using LDT '04 so I'm just a little rusty. How does one create points along a feature line so that the points get their elevation from the line? I'm using the 'measure object' command to create points at 10' intervals along a feature line but they all have an elevation of 0.00.HELP! SINCPAK
