I have a two part question. I use a script to bind xref's(I don't want to get into a debate that it is not good...)
if you bind a drawing by itself when you go to bind, it brings up another dialog box that says "bind" or "insert". The insert feature is nicer, but how do I get this option when I do -xref in my script?
Images, how does one go about binding an image into a file so that there is just a dwg that have photo's in it where you do not need to send the photo's along with the dwg... I often use images for business logo's and it is a pain when you send files the image is not found.
TIA
Pieter
