Author Topic: 3ds Max  (Read 3953 times)
sea-dawg
3ds Max
« on: October 05, 2008, 05:08:11 PM »
I am having trouble with Vray not working. I down loaded the demo version for 32 bit 3ds max (the one that I have) installed it but it wont show up in max. any suggestions?
Tuoni
  • I do stuff, and things!
Re: 3ds Max
« Reply #1 on: October 05, 2008, 05:14:34 PM »
1) What version of max are you running
2) When you say "it won't show up", do you mean it doesn't appear as a valid renderer in the Rendering Options?
sea-dawg
Re: 3ds Max
« Reply #2 on: October 05, 2008, 07:06:00 PM »
2009, yes that is correct it is not coming in as a valid renderer in the rendering options
Tuoni
Re: 3ds Max
« Reply #3 on: October 05, 2008, 07:14:52 PM »
So long as you installed the correct VRay for 2009 and pointed it at your installation correctly (though from memory it should find it on its own) I see no reason why it doesn't appear.
Is there a path in your max configuration ini?  I can't remember whether it installs to the max folder - if it does, can you check whether there is a VRay folder there, if not what is in the install folder?  Is there a configuration program?
Sorry, its been a couple of years since I've used VRay or Max
sea-dawg
Re: 3ds Max
« Reply #4 on: October 05, 2008, 07:30:02 PM »
yes it was in the max folder. I set it find the folder and to install there. But it is not being recognized in Max
Tuoni
Re: 3ds Max
« Reply #5 on: October 05, 2008, 07:32:14 PM »
Sorry, I can't really help past that, short of saying to try re-installing VRay.
sea-dawg
Re: 3ds Max
« Reply #6 on: October 05, 2008, 07:40:41 PM »
i did twice but thanks any way
