Author Topic: INVALID SOLIDS  (Read 2525 times)
JOHNB
INVALID SOLIDS
« on: August 15, 2012, 05:49:58 PM »
Can anyone tell me why solids that are valid one day are invalid when I open the drawing the next day.
Thanks for any help in advance
Regards
JohnB
KewlToyZ
Re: INVALID SOLIDS
« Reply #1 on: August 15, 2012, 10:25:38 PM »
Others using a different version of CAD? Any document management programs used with your CAD files?
Re: INVALID SOLIDS
« Reply #2 on: August 16, 2012, 12:45:27 AM »
System low on memory?
Once upon a time I was getting many invalid solid errors. After upgrading the memory in my system, the problems went away.
Re: INVALID SOLIDS
« Reply #3 on: August 16, 2012, 01:09:48 AM »
Regards
JohnB
John,
Is this issue reproducible or random ?
If randon, I assume "when I open the drawing the next day" is not literal.
Are the solids produced pragmatically ?
if so , how ?
Does the issue apply to ALL solids in a drawing, or only some ??
Which AutoCAD are you using ?
Regards
irneb
Re: INVALID SOLIDS
« Reply #4 on: August 16, 2012, 03:35:37 AM »
Shouldn't that be programmatically? Auto-correct's a b-tch isn't it!
Re: INVALID SOLIDS
« Reply #5 on: August 16, 2012, 03:44:06 AM »
nah .. pragmatic works too :)
JOHNB
Re: INVALID SOLIDS
« Reply #6 on: August 16, 2012, 05:19:30 PM »
To all,
Using windows 7 professional service pack 1 with 6 gb of memory.
autocad 12 64 bit.
The problem seems random, some solids OK others invalid.
Regards
JohnB
Re: INVALID SOLIDS
« Reply #7 on: August 16, 2012, 05:30:27 PM »
Is there a procedure (or specific procedures) performed on the solids that become invalid.
JOHNB
Re: INVALID SOLIDS
« Reply #8 on: August 16, 2012, 07:04:12 PM »
No procedures undertaken. Just close the drawing, reopen at a later date and some solids become invalid.
Re: INVALID SOLIDS
« Reply #9 on: August 16, 2012, 07:36:51 PM »
This is worse than pulling teeth. :)
How are the solids created ?
Are the solids that cause problems created differently to the ones that are OK.
(ie) Are unions, subtractions, extrusions, sweeps etc etc particular to the failures.
JOHNB
Re: INVALID SOLIDS
« Reply #10 on: August 16, 2012, 09:25:49 PM »
Does not appear to be any particular operation that causes the problem
