Author Topic: Unreferenced Images  (Read 3058 times)
chance
Unreferenced Images
« on: October 05, 2006, 11:20:46 AM »
so I am looking at the Image Manager...and there they are....Unreferenced Images....how do I clean out these buggers
Re: Unreferenced Images
« Reply #1 on: October 05, 2006, 11:52:59 AM »
I have a lisp I wrote that will do this. If you'd like to try it just let me know.
pmvliet
« Reply #2 on: October 05, 2006, 11:53:53 AM »
I beleive you can just detach the reference. The only reason why you won't be able to do this is if they are coming in with a referenced file. If they are coming in this way, open the reference file and detach it there.
If it does give you a hard time detaching, you may have to create a dummy image in it's place so that the file is found and then detach that. But that would be an extreme case of it not behaving.
Pieter
Greg B
  • Tell me a Joke!
« Reply #3 on: October 05, 2006, 01:38:43 PM »
Doesn't logic tell anyone that if you have an image "manager", that you should be able to select the unreferenced images in the "manager" and just delete them?
Sorry all, this is a DataCAD feature that seems to just make sense.
« Reply #4 on: October 05, 2006, 02:51:09 PM »
Data wha?? :-D
Greg B
  • Tell me a Joke!
« Reply #5 on: October 05, 2006, 03:55:22 PM »
Data wha?? :-D
Uh yeah....good one.
I haven't heard that before.
« Reply #6 on: October 05, 2006, 04:34:19 PM »
Data wha?? :-D
Glad to have surprised ya...
chance
« Reply #7 on: October 06, 2006, 04:06:37 PM »
may bad....forget to say that the detach function does not come up
pmvliet
« Reply #8 on: October 06, 2006, 04:16:51 PM »
Are you by chance using LT?
that will make a difference...
chance
« Reply #9 on: October 06, 2006, 04:47:37 PM »
no ADT 3.3/Acad 2000
pmvliet
« Reply #10 on: October 06, 2006, 06:03:52 PM »
So what exactly do you mean that the detach function does not come up?
You do have the image manager dialog correct?
if you select the image, do you not have a detach button on the righthand side?
Pieter
chance
« Reply #11 on: October 07, 2006, 12:06:04 PM »
kinda like this
pmvliet
« Reply #12 on: October 07, 2006, 03:52:05 PM »
Ok,
so that image file is coming in from one of your reference files.
open the file that is referenced as "0610504"
then if you go to the image manager in that file, you should be able to detach them.
chance
« Reply #13 on: October 08, 2006, 11:00:22 AM »
that did it....thank you
