Author Topic: Remove double backslash from string?  (Read 3976 times)
mgreven
« on: February 24, 2012, 03:29:40 AM »
Hello,
Maybe i ask a stupid question, but is there a way to replace double backslashes in a string?
I am getting a result from the Filefind routine "C:\\TEMP\\temp.txt" which i want to transform into "C:\TEMP\temp.txt".
I tried it with the vl-string-subst command but i cannot give a single "\" to the routine?
Regards,
Marco
Re: Remove double backslash from string?
« Reply #1 on: February 24, 2012, 05:30:04 AM »
In LISP (and other languages), the backslash is used as an Escape Character to give a sequence of characters an alternative meaning, e.g.:
"\n" = new line character
"\t" = tab character
"\r" = carriage return
Hence, to display a literal backslash you need to mark it as a literal by prefixing it with another backslash ("\\").
This means that a double backslash in LISP is interpreted as a single backslash.
Consider this example program:
  1. (defun c:test ( / str )
  2.     (setq str (getstring t "\nEnter a String with some Backslashes: "))
  3.     (princ "\nString in LISP format: ")
  4.     (prin1 str)
  5.
  6.     (princ "\nString when printed:    ")
  7.     (princ str)
  8.     (princ)
  9. )
To demonstrate:
Command: test
Enter a String with some Backslashes: a\b\c
String in LISP format: "a\\b\\c"
String when printed:   a\b\c
« Last Edit: February 24, 2012, 05:35:17 AM by Lee Mac »
mgreven
« Reply #2 on: February 25, 2012, 02:07:49 AM »
Thanks for your respons...
