Author Topic: Hatches scale display in MPolygon  (Read 5526 times)
gile
  • Marseille, France
« on: June 14, 2009, 10:29:46 AM »
I'm trying to write a command for vanilla acad to convert objects (polylines, 2d polylines, circles) into a MPolygon.
It seems to work, the MPolygon is created with the specified pattern scale but it displays as if the scale was 1.0 even if in the properties palette the scale is as specified.
Add AcMPolygonMGD.dll to References
namespace VanillaMPolygon
    public class MpgClass : IExtensionApplication
        public void Initialize()
            string ver = Application.GetSystemVariable("ACADVER").ToString().Substring(0, 2);
            Autodesk.AutoCAD.Runtime.SystemObjects.DynamicLinker.LoadModule("AcMPolygonObj" + ver + ".dbx", false, false);
        public void Terminate()
        [CommandMethod("PL2MPG")]
        public void PL2MPG()
            Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
            try
                Database db = HostApplicationServices.WorkingDatabase;
                TypedValue[] filter = { new TypedValue(-4, "<or"),
                                           new TypedValue(0, "CIRCLE"),
                                           new TypedValue(-4, "<and"),
                                           new TypedValue(0, "LWPOLYLINE"),
                                           new TypedValue(-4, "&"),
                                           new TypedValue(70, 1),
                                           new TypedValue(-4, "and>"),
                                           new TypedValue(0, "POLYLINE"),
                                           new TypedValue(-4, "<not"),
                                           new TypedValue(70, 120),
                                           new TypedValue(-4, "not>"),
                                           new TypedValue(-4, "or>"),
                SelectionFilter selFilter = new SelectionFilter(filter);
                PromptSelectionResult result = ed.GetSelection(selFilter);
                if (result.Status == PromptStatus.OK)
                    ObjectId[] selSet = result.Value.GetObjectIds();
                        BlockTable bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
                        BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                        MPolygon mPolygon = new MPolygon();
                        PromptStringOptions pso = new PromptStringOptions("\nEnter the hatch pattern name or a dot (.) for none: ");
                        pso.AllowSpaces = false;
                        pso.DefaultValue = (string)Application.GetSystemVariable("HPNAME");
                        PromptResult psr = ed.GetString(pso);
                        if (psr.Status != PromptStatus.OK)
                            return;
                        string pat = psr.StringResult.ToUpper();
                        if (pat != ".")
                            try
                                Application.SetSystemVariable("HPNAME", pat);
                                mPolygon.SetPattern(HatchPatternType.PreDefined, pat);
                                if ((pat != "SOLID") && (pat != "_SOLID"))
                                    PromptDoubleOptions pdo = new PromptDoubleOptions("\nSpecify the scale: ");
                                    pdo.AllowNegative = false;
                                    pdo.AllowZero = false;
                                    pdo.AllowNone = true;
                                    pdo.DefaultValue = (double)Application.GetSystemVariable("HPSCALE");
                                    PromptDoubleResult pdr = ed.GetDouble(pdo);
                                    if (pdr.Status != PromptStatus.OK)
                                        return;
                                    double scale = pdr.Value;
                                    mPolygon.PatternScale = scale;
                                    Application.SetSystemVariable("HPSCALE", scale);
                            catch
                                ed.WriteMessage("\nInvalid pattern: " + pat);
                                return;
                        foreach (ObjectId objId in selSet)
                            Entity ent = (Entity)tr.GetObject(objId, OpenMode.ForRead);
                            if (ent is Polyline)
                                mPolygon.AppendLoopFromBoundary((Polyline)ent, true, 1E-9);
                            else if (ent is Circle)
                                mPolygon.AppendLoopFromBoundary((Circle)ent, true, 1E-9);
                            else
                                mPolygon.AppendLoopFromBoundary((Polyline2d)ent, true, 1E-9);
                        PromptKeywordOptions pko = new PromptKeywordOptions("\nDelete source objects ? [Yes/No]: ", "Yes No");
                        pko.AllowNone = true;
                        pko.Keywords.Default = "No";
                        psr = ed.GetKeywords(pko);
                            return;
                        if (psr.StringResult == "Yes")
                            foreach (ObjectId obj in selSet)
                                Entity ent = (Entity)tr.GetObject(obj, OpenMode.ForWrite);
                                ent.Erase();
                        mPolygon.BalanceTree();
                        if (mPolygon.PatternName != "") mPolygon.EvaluateHatch(true);
                        btr.AppendEntity(mPolygon);
                        tr.AddNewlyCreatedDBObject(mPolygon, true);
                        tr.Commit();
            catch (Autodesk.AutoCAD.Runtime.Exception ex)
                ed.WriteMessage("Error: " + ex.Message);
            catch (System.Exception ex)
« Last Edit: June 14, 2009, 05:44:20 PM by gile »
ReneRam
Re: Hatches scale display in MPolygon
« Reply #1 on: June 15, 2009, 03:56:09 AM »
Hi gile,
I was just having a fast look at TheSwamp, but I think this could help:
http://www.theswamp.org/index.php?topic=20832.msg253549#msg253549
I had a problem while creating and displaying hatch patterns some time ago and gotthe solution here. Take a look at the code sent by "fixo", specially where it says that the order of creating and updating hatch patterns must be kept with the "SetHatchPattern(hatchType, patName)" at the end. I do it when creating and updating.
gile
  • Marseille, France
« Reply #2 on: June 15, 2009, 04:45:36 AM »
Thank you very much Rene (and thanks to Fixo too) this solved my problem.
Edit : new release
using System.Windows.Forms;
using AcApp = Autodesk.AutoCAD.ApplicationServices.Application;
        void IExtensionApplication.Initialize()
            string ver = AcApp.GetSystemVariable("ACADVER").ToString().Substring(0, 2);
        void IExtensionApplication.Terminate()
            Editor ed = AcApp.DocumentManager.MdiActiveDocument.Editor;
            try
                if (result.Status != PromptStatus.OK)
                    return;
                double elev;
                Vector3d norm;
                if (!isValidSelSet(selSet, out elev, out norm))
                    return;
                double scale = (double)AcApp.GetSystemVariable("HPSCALE");
                PromptStringOptions pso = new PromptStringOptions("\nEnter the pattern name or a dot (.) for none: ");
                pso.DefaultValue = (string)AcApp.GetSystemVariable("HPNAME");
                    return;
                 if (pat != ".")
                    try
                        AcApp.SetSystemVariable("HPNAME", pat);
                            PromptDoubleOptions pdo = new PromptDoubleOptions("\nEnter the pattern scale: ");
                            pdo.DefaultValue = scale;
                                return;
                            scale = pdr.Value;
                            AcApp.SetSystemVariable("HPSCALE", scale);
                    catch
                        pat = ".";
                        return;
                PromptKeywordOptions pko = new PromptKeywordOptions("\nErase source objects ? [Yes/No]: ", "Yes No");
                    return;
                    Entity ent;
                    mPolygon.UpgradeOpen();
                    if (pat != ".")
                    mPolygon.DowngradeOpen();
                        ent = (Entity)objId.GetObject(OpenMode.ForRead);
                            mPolygon.AppendLoopFromBoundary((Polyline)ent, true, 1E-12);
                            mPolygon.AppendLoopFromBoundary((Circle)ent, true, 1E-12);
                        else
                            mPolygon.AppendLoopFromBoundary((Polyline2d)ent, true, 1E-12);
                    mPolygon.Elevation = elev;
                    mPolygon.Normal = norm;
                    int cnt = 0;
                            try
                                ent = (Entity)obj.GetObject(OpenMode.ForWrite);
                                ent.Erase();
                            catch
                                cnt++;
                    if (0 < cnt)
                        string msg = cnt == 1 ?
                            " object on locked layer will not be erased" :
                            " objects on locked layer will not be erased";
                        MessageBox.Show(
                            cnt.ToString() + msg,
                            "PL2MPG",
                            MessageBoxButtons.OK,
                            MessageBoxIcon.Exclamation);
                     tr.Commit();
        private bool isValidSelSet(ObjectId[] selSet, out double elev, out Vector3d norm)
            Polyline pl;
            Circle circ;
            Polyline2d p2d;
            Tolerance tol = new Tolerance(1E-12, 1E-12);
                Entity ent = (Entity)selSet[0].GetObject(OpenMode.ForRead);
                pl = ent as Polyline;
                if (pl != null)
                    elev = pl.Elevation;
                    norm = pl.Normal;
                else
                    circ = ent as Circle;
                    if (circ != null)
                        elev = circ.Center.TransformBy(Matrix3d.WorldToPlane(circ.Normal)).Z;
                        norm = circ.Normal;
                    else
                        p2d = ent as Polyline2d;
                        elev = p2d.Elevation;
                        norm = p2d.Normal;
                for (int i = 1; i < selSet.Length; i++)
                    ent = (Entity)selSet[i].GetObject(OpenMode.ForRead);
                    if (pl != null)
                        if ((elev - pl.Elevation) > 1E-12)
                            ed.WriteMessage("\nThe objects doesn't have the same elevation.");
                            tr.Commit();
                            return false;
                        else if (!norm.IsEqualTo(pl.Normal, tol))
                            ed.WriteMessage("\nThe objects doesn't have the same normal.");
                            tr.Commit();
                            return false;
                    else
                        if (circ != null)
                            if ((elev - circ.Center.TransformBy(Matrix3d.WorldToPlane(circ.Normal)).Z) > 1E-12)
                                ed.WriteMessage("\nThe objects doesn't have the same elevation..");
                                tr.Commit();
                                return false;
                            else if (!norm.IsEqualTo(circ.Normal, tol))
                                tr.Commit();
                                return false;
                        else
                            if ((elev - p2d.Elevation) > 1e-12)
                                tr.Commit();
                                return false;
                            else if (!norm.IsEqualTo(p2d.Normal, tol))
                                tr.Commit();
                                return false;
                tr.Commit();
                return true;
« Last Edit: June 16, 2009, 06:06:22 PM by gile »
gile
  • Marseille, France
« Reply #3 on: June 16, 2009, 06:09:55 PM »
New version: added a function to evaluate if selected objects have the same elevation and normal.
It works whatever the source objects construction plane (just need to be the same for all objects)
« Last Edit: June 17, 2009, 02:24:56 AM by gile »
Bryco
« Reply #4 on: July 24, 2009, 04:33:45 PM »
gile I have used your filter list to filter for hatchable items but I would like to add a filter for elliptic arcs. I can't figure out quite how to do it. the following doesn't work when you uncomment the applicable lines
    static private SelectionFilter HatchFilterlist()
            TypedValue[] filterlist = {
                new TypedValue(0, "Circle,Spline,Region"),
                new TypedValue(0, "Lwpolyline"),
                new TypedValue(70,1),
                new TypedValue(0, "Ellipse"),
                //new TypedValue(-4, "&"),
                //new TypedValue(41,0.00),
                //new TypedValue(42,2*Math.PI),
                new TypedValue(-4, "or>"),};
            SelectionFilter sf = new SelectionFilter(filterlist);
            return sf;
SEANT
« Reply #5 on: July 26, 2009, 03:27:13 AM »
The bitwise operator “&” is only compatible with integers.  If that’s left out will it filter as expected?
                [color=green]//new TypedValue(-4, "&"),[/color]
Sean Tessier
AutoCAD 2016 Mechanical
Bryco
« Reply #6 on: July 27, 2009, 12:23:45 PM »
Thanks Sean that did the trick. I eventually found the help on this in Lisp (never use it)
                new TypedValue(0, "Circle,Region"),
                new TypedValue(0, "Lwpolyline,Spline"),
            return sf;
        }//End HatchFilterlist
It's odd that I even have to use new TypedValue(-4, "&") in the above, but it doesn't work for plines and splines without it
SEANT
« Reply #7 on: July 27, 2009, 01:36:15 PM »
I think the problem is that “Closed” is bitcoded with other properties which may not have relevance to a particular routine, but prevent a focused search for a value of 1.
In that light, and given that the routine will eventually create hatches, the spline filter may also need to account for the non-planar variety.  I haven’t tested it but:
new TypedValue(0, "Spline"),
new TypedValue(-4, "&="),
new TypedValue(70,9),
Sean Tessier
