Author Topic: trying to understand the difference  (Read 1519 times)
cadman6735
« on: May 14, 2013, 02:42:50 PM »
What is the difference?
(ssget "x" '((2 . "BLOCKNAME")))   ;works
(ssget “x” (list  (cons 2 “BLOCKNAME”)))    ;works
(setq *value* "BLOCKNAME")
(ssget "x" '((2 . *value*)))   ;does not work   <------  why does this not accept variables?
(ssget “x” (list  (cons 2 *value*)))    ;works
dgorsman
Re: trying to understand the difference
« Reply #1 on: May 14, 2013, 03:13:31 PM »
The single quote is essentially saying "use this as is", so it is literally ((2 . *value*))) not the value you are trying to pass.  If you want to dynamically change the condtions, you will need to manually construct the list with calls to (list ...) and (cons ...).
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
cadman6735
« Reply #2 on: May 14, 2013, 03:18:17 PM »
Thank you
Tharwat
  • Hypersensitive
« Reply #3 on: May 14, 2013, 03:19:45 PM »
No evaluation or expression after the quote symbol ( ' ) in other words , it is a dummy expression or static one .
Hope this helps .
« Reply #4 on: May 14, 2013, 03:46:49 PM »
Maybe this explanation will also shed some light on the topic:
http://www.cadtutor.net/forum/showthread.php?75708&p=513602&viewfull=1#post513602
cadman6735
« Reply #5 on: May 14, 2013, 04:59:48 PM »
Yes, I understand now,
Thank you all...
cadman6735
« Reply #6 on: May 14, 2013, 05:09:24 PM »
lee, your link, very informative and easy to understand... thanks
« Reply #7 on: May 14, 2013, 05:26:38 PM »
Excellent, thanks  8-)
