Author Topic: plinewid-Help  (Read 2006 times)
rude dog
plinewid-Help
« on: March 27, 2008, 11:45:27 PM »
I have a routine that draws a closed polyline that works good. I am stuck
on assigning width to it with staright VBA I tried this but it doenst work:
   ThisDrawing.SetVariable "PLINEWID", 0.0625
    Set plineObj = ThisDrawing.ModelSpace.AddLightWeightPolyline(points)
    plineObj.Closed = True
I was trying to avoid looping through each segment, and SendCommand with autolisp
This is my first crack @ VBA
Bryco
Re: plinewid-Help
« Reply #1 on: March 28, 2008, 12:07:27 AM »
Dim plineObj As AcadLWPolyline
Set plineObj = ThisDrawing.ModelSpace.AddLightWeightPolyline(Points)
plineObj.SetWidth 0, 4, 5
rude dog
Re: plinewid-Help
« Reply #2 on: March 28, 2008, 12:20:23 AM »
Thank You for the speedy help
Now I can go to bed peacefully...
worked great 8-)
