Author Topic: Diesel Expression for a block count  (Read 10489 times)
whdjr
« on: October 06, 2005, 09:43:14 AM »
Can someone pen me a diesel expression to count the number of blocks in a drawing?
Block name is "12X12".
Thank You,
whdjr
Re: Diesel Expression for a block count
« Reply #1 on: October 06, 2005, 11:48:46 AM »
If I wrote an AutoLisp function to be called using diesel can I pass it an argument?
whdjr
« Reply #2 on: October 06, 2005, 03:25:31 PM »
Did I do something wrong on the boards here?  It seems like I can't get anybody to respond to my posts.
If you don't have an answer please point me in the right direction.
deegeecees
« Reply #3 on: October 06, 2005, 03:29:24 PM »
The Right Direction --------------------------------------------->
whdjr
« Reply #4 on: October 06, 2005, 03:34:58 PM »
 :realmad:
 :pissed:
« Reply #5 on: October 06, 2005, 05:03:47 PM »
Diesel cannot do data collection .. it can only do variable processing
Bob Wahr
« Reply #6 on: October 06, 2005, 05:10:33 PM »
What exactly are you needing from it?  If all you need is a one time or periodic count of the block, you could use FILTER.  If you need a running total, it would be a fairly easy undertaking in VBA and probably lisp.
whdjr
« Reply #7 on: October 06, 2005, 05:41:12 PM »
I made a dynamic block with a 12" square block inside it called "12X12".  I put an array parameter with a spacing of 12".  I put some mtext in the block to label what it was and I was trying to get it to count the number of "12X12" blocks inside the dynamic block.  Sounds easy right?  Not!  Dynamic blocks allow you to get autolisp system variables and allow you to input any diesel expression.  Since I couldn't find what I needed I thought I would try to get the number of blocks with diesel, but I don't know diesel.  I wrote a small lisp file to count the blocks but I couldn't get it to work thru diesel.
Does that make any sense at all? :|
Andrea
« Reply #8 on: October 10, 2005, 11:44:08 PM »
whdjr ...
why using diesel expression...
sur you can....but not very useful..
try the FIELD option...or BCOUNT.
Keep smile...
whdjr
« Reply #9 on: October 11, 2005, 09:54:28 AM »
whdjr ...
I was using the field option but it doesn't let you run acad commands (unless I missed something) only get system variables - same as with diesel.  I wrote a lisp prog to count my blocks and didn't know if there was a way to call a lisp file with diesel.
Andrea
« Reply #10 on: October 11, 2005, 10:38:56 AM »
ok...
but...
Why exaclty use diesel ??
In your lisp program you must have your block count in a variable right ?
try to use this variable with..
$(GETVAR, your variable)
or...there is my block count program.
B L I S T ;
Par: Andrea Andreetti ;
2005-08-4 ;
Programme permettant de calculer le nombre ;
de bloc selon la couche spécifié. |;
EXÉCUTION MBLIST ;
(defun c:MBlist ()
(setq la1 nil)
(setq la3 nil)
 (setq bname (ssget))
  (if (not bname)
      (alert " No entity was selected.")
      (exit)
 (setq sscount (sslength bname))
 (setq val1 (- sscount 1))
 (setq tlen 0)
 (repeat sscount
   (setq a1 (entget (ssname bname val1)));;détail de l'entité
   (setq a2 (cdr (assoc 2 a1)));;nom du block
   (if a2
     (setq a3 (cdr (assoc 8 a1)));;nom du de la couche
     (setq BLitem (strcat a2 "," a3))
     (setq la1 (append la1 (list BLitem)))
;;;     (createfile)
     );;progn
   );;if
   (setq val1 (- val1 1))
 );;end repeat
(if (not a3)
    (alert " No Block was detected in this selection.")
    (exit)
(setq la1 (acad_strlsort la1))
  (setq cont 1)
    (setq itemp (car la1))
    (setq lalist (cdr la1))
  (foreach a la1
    (if (= itemp (car lalist))
      (setq cont (+ cont 1))
      (setq itemp (car lalist))
      (setq lalist (cdr lalist))
      (setq la2 (strcat (rtos cont) "," itemp))
      (setq la3 (append la3 (list la2)))
      (setq cont 1)
    );;if
  );;foreach
(setq F_space "                              ")
(setq dwglengt (- (strlen (getvar "DWGNAME")) 4))
(setq MBfilename (substr (getvar "DWGNAME") 1 dwglengt))
(setq MBlistfilename (strcat (getvar "DWGPREFIX") MBfilename ".txt"))
(setq projetname (strcat (getvar "DWGPREFIX") (getvar "DWGNAME")))
(initget 1 "Yes No")
(setq question1 (strcase (getkword "Do you want to export the result in txt file ? (Yes/No) ")))
(if (= question1 "YES") (MBexportlist))
(if (= question1 "NO") (MBscreenonly))
(MBresetvar)
(defun MBresetvar ()
  (setq la1 nil
la3 nil
bname nil
sscount nil
val1 nil
tlen nil
a1 nil
a2 nil
a3 nil
BLitem nil
la1 nil
la2 nil
la3 nil
val1 nil
cont nil
        projetname nil
itemp nil
lalist nil
F_space nil
dwglengt nil
MBfilename nil
MBlistfilename nil
FLA1 nil
virgule1 nil
virgule2 nil
vig1 nil
vig2 nil
MBi1 nil
MBi2 nil
MBi3 nil
MBi1# nil
space1 nil
space2 nil)
SCREEN ONLY ;
(defun MBscreenonly ()
(princ
                   Block List RESULT with MBlist
                   _____________________________
;;(princ (strcat "\n\nProjet:      " projetname))
(princ (strcat "\n\nDWG File: " projetname))
(princ (strcat "\n\nDate:        " (menucmd "M=$(edtime,$(getvar,date),YYYY MON D H:MMam/pm)")))
(princ "
______________________________________
Qty:        Block name:         Layer:" )
(foreach b la3
(setq FLA1 (car la3))
  (setq virgule1 (vl-string-position 44 FLA1))
  (setq virgule2 (vl-string-position 44 (substr FLA1 (+ virgule1 2))))
  (setq vig1 (+ virgule1 2))
  (setq vig2 (+ virgule1 virgule2 3))
  (setq MBi1 (substr b 1 virgule1)
MBi2 (substr b vig1 virgule2)
MBi3 (substr b vig2)
  );;setq
(setq MBi1# (- 12 (strlen MBi1)))
(setq space1 (substr F_space 1 MBi1#))
(setq MBi2# (- 20 (strlen MBi2)))
(setq space2 (substr F_space 1 MBi2#))
(princ (strcat "\n" MBi1 space1 MBi2 space2 MBi3))
(setq la3 (cdr la3))
);;foreach
  (textscr)
EXPORTATION dans un fichier TXT ;
(defun MBexportlist ()
(setq MBfile (open MBlistfilename "w"))
(write-line "                  Block List RESULT with MBlist" MBfile)
(write-line "                  ___________________________________" MBfile)
;;(write-line (strcat "\n\nProjet:      " projetname) MBfile)
(write-line (strcat "\nDWG File: " projetname) MBfile)
(write-line (strcat "\nDate:        " (menucmd "M=$(edtime,$(getvar,date),YYYY MON D H:MMam/pm)")) MBfile)
(write-line "\n\n\n______________________________________" MBfile)
(write-line "\nQty:        Block name:         Layer:" MBfile)
(foreach b la3
  );;setq
(write-line (strcat "\n" MBi1 space1 MBi2 space2 MBi3) MBfile)
);;foreach
(close MBfile)
(command "start" (strcat MBfilename ".txt"))
(PRINC
________________________________________By Andrea Andreetti
Programme MBlist version 1.0
write \"MBlist\" to start")
hope this will help
Keep smile...
whdjr
« Reply #11 on: October 11, 2005, 10:56:41 AM »
This is what I was going to use and just pass it the name of my block so that I could use it in other places.
(defun c:bcount (str)
  (rtos
    (sslength (ssget "x" (list '(0 . "INSERT") (cons 2 str))))
    2
    0
Andrea
« Reply #12 on: October 11, 2005, 11:20:21 AM »
whdjr...
be careful..there is already a command in autocad called BCOUNT.
i'm not sure exactly what you need to do...
can you explain ?
my english is like my spanish some time.. :|
Keep smile...
« Reply #13 on: October 11, 2005, 11:28:09 AM »
Will,
FYI
That will fail if there are no such block in the drawing.
Andrea
« Reply #14 on: October 11, 2005, 11:51:00 AM »
if you have 2006..
you can also use
eattext function to associate # of block in table.
just for info.
Keep smile...
