Author Topic: Align Multiple Text Objects to Curve  (Read 440 times)
encepta
  • Mosquito
« on: April 15, 2024, 01:05:18 PM »
Problem: I need to align multiple text objects to curve.
LeeMac's DTCurve does exactly what I need but it only allows one text to be aligned at a time...
Any thoughts/ideas? I do not want to loop this function because that also results in a ton of clicks.
https://www.lee-mac.com/dtcurve.html
xdcad
Re: Align Multiple Text Objects to Curve
« Reply #2 on: April 15, 2024, 09:13:06 PM »
You can specify the distance after alignment
https://www.theswamp.org/index.php?topic=59245.0
https://github.com/xdcad
http://bbs.xdcad.net
reyas1123
« Reply #3 on: April 21, 2024, 07:36:21 AM »
Dear Sir,
i downloaded the file and save to lsp file but has an error. tnx
ReyAs
xdcad
« Reply #4 on: April 21, 2024, 09:52:51 PM »
Dear Sir,
ReyAs
Have you downloaded the API compressed package at https://github.com/xdcad/XDrx-API, decompressed it, and installed the files inside?
During installation, check all of them. After installation, start ACAD and check with F2. There will be a prompt whether the API is loaded.
│  ≡ XDRX_API For AutoCAD Build 2024.04.28 ≡  │
│  http://www.xdcad.net  Mail:7598165@qq.com  │
If normal,
It is possible to run the forum LISP
reyas1123
« Reply #5 on: April 22, 2024, 03:56:27 AM »
Thank you so much
Dear Sir,
ReyAs
If normal,
