(defun c:XDTB_TJHATCH (/ blk clr e ha hascl head height keyword ln lst lyr mode name pt row scl ss str tarea tb x y ) (defun _prompt () (xdrx_prompt (xdrx-string-multilanguage "\n统计方式:按*" "\nStatistical method: press *" ) (cond ((= #mode 0) (setq head (xdrx-string-multilanguage (list "图 例" "图 层" "数 量" "总面积" ) (list "legend" "layer" "quantity" "The total area" ) ) ) (xdrx-string-multilanguage "图层" "Layer") ) ((= #mode 1) (setq head (xdrx-string-multilanguage (list "图 例" "颜色号" "数 量" "总面积" ) (list "Legend" "Color" "Quantity" "The total area" ) ) ) (xdrx-string-multilanguage "颜色" "Color") ) (t (setq head (xdrx-string-multilanguage (list "图 例" "模 式" "数 量" "总面积" ) (list "Legend" "Model" "Quantity" "The total area" ) ) ) (xdrx-string-multilanguage "模式" "Mode") ) ) "*" ) ) (defun _keyword (keyword) (cond ((= keyword "TC") (setq #mode 0) ) ((= keyword "YS") (setq #mode 1) ) (t (setq #mode 2) ) ) (_prompt) ) (defun _name (x mode) (cond ((= mode "layer") (car (xdrx_getpropertyvalue x mode)) ) ((= mode "color") (setq ln (xdrx_getpropertyvalue x mode)) (if (= (type ln) 'LIST) (setq ln (apply 'xdrx_color_rgb2aci ln ) ) (progn (if (= ln 256) (progn (setq lyr (cadr (xdrx_getpropertyvalue x "layer"))) (setq ln (xdrx_getpropertyvalue lyr "color")) ) ln ) ) ) (fix ln) ) (t (setq ln (xdrx_getpropertyvalue x mode)) ) ) ) (defun _maketuli (clr mode) (setq clr (fix clr)) (setq name (xdrx_prompt "XD-TJ-HA-" mode "-" clr t)) (if (not (setq blk (xdrx_object_get "block" name))) (progn (setq e (xdrx_polyline_make (xd::pnt:getrecpnts '(0 0 0) (* scl 10.) (* 5 scl) ) t ) ) (xdrx_setpropertyvalue e "constantwidth" (* scl 0.3) "color" 7 ) (setq ha (xdrx_hatch_make e)) (if (= #mode 2) (progn (setq hascl (XD::Hatch:GetSclByGap mode (* 1.414 scl) ) ) (xdrx_setpropertyvalue ha "PatternScale" hascl "patternname" (list 1 mode) ) ) ) (xdrx_setpropertyvalue ha "color" clr "patternname" mode) (xdrx_block_make (strcase name) (list e ha) '(0 0 0.) t) (xdrx_entity_delete (entlast)) (setq blk (xdrx_object_get "block" name)) (xdrx_entity_setproperty (xdrx_block_getentities blk ' ( (0 . "LWPOLYLINE") ) ) "COLOR" 7 ) (xdrx_draworder->back (xdrx_block_getentities blk ' ( (0 . "HATCH") ) ) ) ) ) blk ) (defun _makelst (ss mode) (setq lst (mapcar '(lambda (x) (list (_name x mode) x) ) (xdrx_pickset->ents ss) ) ) ) (defun _getHa (str) (cond ((= #mode 0) (setq e (ssget "x" (list (cons 8 str) '(0 . "HATCH"))) e (ssname e 0) clr (xdrx_getpropertyvalue e "color" t) ) (_makeTuLi clr "SOLID") ) ((= #mode 1) (_makeTuLi str "SOLID") ) (t (setq e (ssget "x" (list (cons 2 str))) e (ssname e 0) clr (xdrx_getpropertyvalue e "color" t) ) (_makeTuLi clr str) ) ) ) (defun _data () (cond ((= #mode 0) (setq lst (_makelst ss "layer")) ) ((= #mode 1) (setq lst (_makelst ss "color")) ) (t (setq lst (_makelst ss "patternname")) ) ) (setq lst (xd::list:groupbyindex lst 1e-3) lst (vl-sort lst '(lambda (x y) (if (= (type (car x)) 'LIST) (< (caar x) (caar y)) (< (car x) (car y)) ) ) ) lst (if (= #mode 1) (mapcar '(lambda(x)(cons (fix (car x))(cdr x))) lst) lst) lst (mapcar '(lambda (x) (list (_getHa (car x)) (car x) (length (cdr x)) (rtos (apply '+ (mapcar '(lambda (y) (xdrx_getpropertyvalue y "area") ) (cdr x) ) ) 2 1 ) ) ) lst ) total (itoa (apply '+ (mapcar 'caddr lst ) ) ) lst (cons head lst) lst (cons (list (xdrx-string-multilanguage "填充面积统计表""Hatch Area Statistics") "" nil nil) lst) tarea (mapcar 'last lst ) tarea (apply '+ (mapcar 'atof (cddr tarea) ) ) lst (append lst (list (list (xdrx-string-multilanguage "合 计""Total") nil total (rtos tarea 2 1))) ) ) ) (defun _table () ;(xdrx_draworder->back xd_blks) (if (setq pt (getpoint (xdrx-string-multilanguage "\n表格插入点<退出>:" "\nTable insertion point<Exit>:" ) ) ) (progn (xd::text:init 1) (setq tb (XD::Table:MakeFromList lst (trans pt 1 0) #height (/ #height 2.0) ) ) ; (setq row (1- (length lst))) ; (xdrx_table_MergeCells tb row row ; 0 1) ; (xdrx_table_SetTextString tb row 0 ; "合 计") ; (xdrx_setpropertyvalue tb ; "mergecells" (list row row 0 1) ; "textstring" (list row 0 "合 ; 计") "color" 7) ) ) ) (xdrx_begin) (xdrx_sysvar_push '("dimzin" 0)) (if (not #mode) (setq #mode 0) ) (if (not #height) (setq #height 4.) ) (setq scl (* (xd::var:getratio) (xd::var:getscaleratio))) (if (setq height (getreal (strcat (xdrx_prompt (xdrx-string-multilanguage "\n表格字高<" "\nTable Text Height<" ) #height ">:" t ) ) ) ) (setq #height height) ) (if (and (_prompt) (xdrx_initssget (xdrx-string-multilanguage "\n选取要统计的填充[图层(TC)/颜色(YS)/模式(MS)]<退出>:" "\nSelect the fill to be counted [Layer(TC)/Color(YS)/Mode(MS)]<Exit>:" ) "TC YS MS" (xdrx-string-multilanguage "移除不统计的填充[添加(A)]<退出>:" "Remove uncounted padding [Add(A)]<Exit>:" ) "_keyword" "" ) (setq ss (xdrx_ssget '((0 . "HATCH")))) ) (progn (setq #scl (/ #height 4.0)) (setq lst (_data)) (_table) ) ) (xdrx_sysvar_pop) (xdrx_end) (princ))
