Author Topic: Draw a 3dpoly with point in a list  (Read 6931 times)
Amsterdammed
« on: September 23, 2005, 09:45:04 AM »
Hello everybody.
The challenge I face today is to draw a 3dpoly line with points coming out of a list. The length of the list can vary.
Any Ideas?
Thanks in Advance
Bernd
Peter Jamtgaard
Re: Draw a 3dpoly with point in a list
« Reply #1 on: September 23, 2005, 11:00:23 AM »
(defun Draw3dpoly (lstOfPoints / lstPoint)
  (command "3dpoly")
  (foreach lstPoint lstOfPoints
    (command lstPoint)
  (command "")
« Reply #2 on: September 23, 2005, 11:10:02 AM »
(apply 'command
    (append
       '(".3dpoly")
        points
« Reply #3 on: September 23, 2005, 11:17:38 AM »
(defun foo ( points )
    (entmake
           (0 . "POLYLINE")
           (100 . "AcDbEntity")
           (100 . "AcDb3dPolyline")
           (66 . 1)
           (10 0.0 0.0 0.0)
           (70 . 8)
           (40 . 0.0)
           (41 . 0.0)
           (210 0.0 0.0 1.0)
           (71 . 0)
           (72 . 0)
           (73 . 0)
           (74 . 0)
           (75 . 0)
    (foreach point points
        (entmake
            (append
                   (0 . "VERTEX")
                   (100 . "AcDbVertex")
                   (100 . "AcDb3dPolylineVertex")
                (list (cons 10 point))
                   (40 . 0.0)
                   (41 . 0.0)
                   (42 . 0.0)
                   (70 . 32)
                   (50 . 0.0)
                   (71 . 0)
                   (72 . 0)
                   (73 . 0)
                   (74 . 0)
    (entmake
           (0 . "SEQEND")
« Reply #4 on: September 23, 2005, 12:15:27 PM »
(defun foo2 ( points / *error* document space )
    ;;  a different way to handle bozo input
            (or
                (null (listp points))
                (< (length points) 2)
                (null
                    (vl-every
                       '(lambda (point)
                            (apply 'and
                                (mapcar
                                   'numberp
                                    point
                        points
            (defun *error* (x)
                (princ
                    (strcat
                        "Bozo alert: Must be a list "
                        "of at least 2 points.\n"
            (exit)
    ;;  let's rock it out
    (setq space
            (zerop
                (vla-get-activespace
                    (setq document
                        (vla-get-activedocument
                            (vlax-get-acad-object)
            (vla-get-paperspace document)
            (vla-get-modelspace document)
    (vlax-invoke-method
        space
       'Add3DPoly
        (vlax-safearray-fill
            (vlax-make-safearray
                vlax-vbdouble
                (cons 0
                    (1-
                        (length
                            (setq points
                                (apply 'append
                                    (mapcar
                                       '(lambda (point)
                                            (while (< (length point) 3)
                                                (setq point
                                                    (append point
                                                      '(0)
                                            point
                                        points
            points
« Last Edit: September 23, 2005, 02:58:42 PM by MP »
Amsterdammed
« Reply #5 on: September 23, 2005, 07:19:22 PM »
Wou,
eh, thanks Micheal. I'm impressed.
Bernd
« Reply #6 on: September 23, 2005, 07:31:26 PM »
Wou,
eh, thanks Micheal.
Bernd
My pleasure. I frequently get kinda chatty after a migraine (yesterday I was wiped out).
« Reply #7 on: September 23, 2005, 07:44:50 PM »
Now, ... THIS is funny.
[added]
The comparisons of code I mean ..
.. perhaps I do need testing after all.
« Last Edit: September 23, 2005, 08:16:14 PM by Kerry Brown »
« Reply #8 on: September 23, 2005, 08:08:28 PM »
(apply 'command
    (append
       '(".3dpoly")
        points
What the . . .   didn't know you could do that
Thanks for the lesson Michael.  :kewl:
LE
« Reply #9 on: September 23, 2005, 08:20:33 PM »
other....
  (command "_.pline")
  (mapcar 'command pts)
  (command "_c")
« Reply #10 on: September 23, 2005, 08:21:35 PM »
Yes Mark, thats very pretty isn't it.
LE
« Reply #11 on: September 23, 2005, 08:24:36 PM »
Or...
$ (setq pts (list a b c d "_c"))
((-6.67905 14.9635 0.0) (-3.9975 13.5826 0.0) (-6.09851 12.3811 0.0) (-6.99697 13.403 0.0) "_c")
_$ (command "_.pline")
LE
« Reply #12 on: September 23, 2005, 08:26:53 PM »
or...
$ (setq pts (list "_.pline" a b c d "_c"))
("_.pline" (-6.67905 14.9635 0.0) (-3.9975 13.5826 0.0) (-6.09851 12.3811 0.0) (-6.99697 13.403 0.0) "_c")
« Reply #13 on: September 23, 2005, 08:28:53 PM »
And the hits just keep on coming. Very nice Luis.  :kewl:
« Reply #14 on: September 23, 2005, 08:30:33 PM »
Indeed it is.  You guys never cease to amaze me.
