Author Topic: Filtering strings . . .  (Read 5466 times)
Re: Filtering strings . . .
« Reply #15 on: March 18, 2009, 04:41:11 PM »
Michael he wants the blank lines included, I think. 8-)
Although they need to be of one space character.
John, it is the filtering he is struggling with.
(defun filereader (str file)
      (if str
        (cons
  (if (or (wcmatch str "01`.###*" ) (eq str ""))
            (list str))
          (filereader (read-line file) file))))
Like this? ...im lost.
EDIT:
MP has a better filter!
> If you want to retain the blank lines just change the wcmatch pattern to "01`.###*,".
Good one!
« Reply #16 on: March 18, 2009, 04:49:55 PM »
Let's play "What If"
What if there are 100 lines in the data file & 20% are blank lines?
I don't think he wanted ALL the blank lines.  8-)
« Reply #17 on: March 18, 2009, 04:54:13 PM »
...Im going home.
« Reply #18 on: March 18, 2009, 05:11:05 PM »
Was it something I said?
Just kidding. :-)
My strategy is to allow the first & last blank line to be added to the list as well as any single blank line found within the target prefix.
You could strip off the first & last easy enough. I don't allow for two or more blank lines in secession.
My test file:
00          Header
00.001    Subheader
01          INTERIOR KEYNOTES
01.001    SCHEDULED DOOR
01.002    WALL PARTITION
01.100    USE PEANUT BUTTER TO CAULK WINDOW FRAME
01.101    TEMPERED GLASS
01.200    BLH, BLAH, BLAH
02          EXTERIOR KEYNOTES
03
04
Result:
     "01          INTERIOR KEYNOTES"
     "01.001    SCHEDULED DOOR"
     "01.002    WALL PARTITION"
     "01.100    USE PEANUT BUTTER TO CAULK WINDOW FRAME"
     "01.101    TEMPERED GLASS"
     "01.200    BLH, BLAH, BLAH"
« Last Edit: March 18, 2009, 05:14:43 PM by CAB »
« Reply #19 on: March 18, 2009, 05:18:29 PM »
Is that really what he wants? If so perhaps:
(defun CleanUpIsleFour ( lst / flag )
    (vl-remove-if-not
       '(lambda ( x )
            (or
                    (wcmatch (setq x (vl-string-trim " \t" x)) "01`.###*")
                    (null (setq flag nil))
                    (eq x "")
                    (null flag)
                    (setq flag t)
        lst
(CleanUpIsleFour
        "02          EXTERIOR KEYNOTES "
/shrug
« Reply #20 on: March 18, 2009, 05:26:40 PM »
Maybe this?
(defun ReadFile ( fullPath ftrPat / Opened tempStr StrList)
    (setq Opened (open fullPath "r"))
    (while (setq tempStr (read-line Opened))
        (if (wcmatch tempStr ftrPat)
                (setq StrList
                    (cons
                        (if (= tempStr "")
                            tempStr
                        StrList
                        (or
                            (= tempStr "")
                        (setq StrList
                            (cons
                                (if (= tempStr "")
                                    tempStr
                                StrList
    (close Opened)
    StrList
« Reply #21 on: March 18, 2009, 05:28:30 PM »
Very nice Michael.
Yes I think that is it.
See example.
http://www.theswamp.org/index.php?topic=27880.msg334605#msg334605
« Reply #22 on: March 18, 2009, 10:01:23 PM »
Thanks Alan. I wonder though if the leading and trailing "" items are acceptable.
Daniel J. Ellis
« Reply #23 on: March 19, 2009, 04:26:05 AM »
Bit beyond my real code, but in pseudo code would:
print out your header information
read all the lines into a list
process the list, line at a time
   If the line starts "01" grab that line into a variable
   bolt on a carriage return preceding the variable, outputting the two to a new variable
move onto the next item in the list
when finished, output the whole lot enmasse to wherever it needs to go
not do the trick?
Adding the carriage return *before* the line gives you a preceding line between your header and the first line, and eliminates a probably undesirable trailing line at the end
dJE
dJE
« Reply #24 on: March 19, 2009, 09:06:34 AM »
I'd say not because he is going to use the list in a DCL list box.
« Reply #25 on: March 19, 2009, 09:30:08 AM »
One more attempt. Using "01." as the prefix and this new version eliminated leading & trailing blank lines.
Though not near as eloquent as Michael's it gets the job done. Michael's gives me something to strive for.
;;  return only lines that start with "01."
(defun c:frtest (/ fname fn ln AllLines lst blank)
  (setq fname "MyFile.txt"
        prefix "01."
        pflen  (strlen prefix))
  (if (setq fn (findfile fname)) ; only if the file is found
    (progn ; fn contains the full path
      (setq fn (open fn "r")) ; open file for reading
      ;;  for speed read all the lines in the file
      (while (setq ln (read-line fn))
(setq AllLines (cons ln AllLines))
      (close fn) ; close the open file handle
      (foreach ln (reverse AllLines)
        ;;  remove leading and trailing tabs & spaces
        (setq ln (vl-string-trim " \t" ln))
        ;;  filter
          ((and blank (= ln ""))
           (setq lst (cons " " lst)) ;  add one space line
           (setq blank nil) ; disallow another blank line
          ((= (substr ln 1 pflen) prefix)
           (setq lst (cons ln lst)) ;  collect the line
           (setq blank t) ; allow one blank line to follow
 (if (= " " (car lst))
   (reverse (cdr lst))
   (reverse lst)
« Reply #26 on: March 19, 2009, 09:47:53 AM »
If so then perhaps:
(defun CleanUpIsleFour ( lst / result flag )
        (eq ""
            (car
                (setq result
                    (vl-remove-if-not
                       '(lambda ( x )
                            (or
                                    (wcmatch x "01`.###*")
                                    (eq x "")
                                    (null flag)
                                    (setq flag t)
                        (mapcar '(lambda ( x ) (vl-string-trim " \t" x)) lst)
        (setq result (cdr result))
    (if (eq "" (last result))
        (reverse (cdr (reverse result)))
        result
(CleanUpIsleFour
PS: Thanks for the undeserved nice words Alan.
jbuzbee
« Reply #27 on: March 19, 2009, 10:46:14 AM »
You guys are hopeless!  I said psuedo code, but no - you guy's can't pass up the oppurtunity can you?  I think there is a twelve step program for this sort of thing.
 :-D
Just kidding!  There's some pretty good code here guys, thankyou very much.  I'm not at my computer with all my source code so I'll have to try some of this stuff out tonight.  Thanks again.
(CleanUpIsleFour - pretty funny stuff MP)
James Buzbee
Windows 8
