Author Topic: Finding objects inside INSERT/BLOCK  (Read 1612 times)
Woabow
« on: May 13, 2013, 01:47:11 PM »
There are several routines that lists the contents of a BLOCK. They will return the same data for any instance of a BLOCK in the drawing.
But what if I would like to have the contents of the INSERT, or in my case, I just want to have a list with all lines inside an INSERT with the drawing-WCS-coordinates of the lines.
Do I have to find the contents of a BLOCK first and "multiply" it with the INSERT matrix?
Re: Finding objects inside INSERT/BLOCK
« Reply #1 on: May 13, 2013, 04:03:09 PM »
Yes  :-)
Woabow
« Reply #2 on: May 13, 2013, 04:10:07 PM »
Great :cry:
Our blocks are often nested, gives me headaches... Maybe it is easier to explode the blocks with an undo mark, collect the info and do an undo....
« Reply #3 on: May 13, 2013, 04:29:29 PM »
This program may help you with the matrix transformations: Extract Nested Block, the key is gile's refgeom function.
Woabow
« Reply #4 on: May 14, 2013, 11:39:59 AM »
Thanks Lee, Ill give it a try.
