Author Topic: Make Ribbon Tab Current  (Read 6233 times)
trogg
« on: April 17, 2012, 02:08:14 PM »
Does anyone know of a way to make a tab of the ribbon current via a lisp or script?
I was hoping for a system variable but couldn't find one.
I am aware of using the Alt button to display the letters and being able to hit "H" for example and making the Home tab current but it would be nice to include something like this in some routines.
thanks
~Greg
BlackBox
Re: Make Ribbon Tab Current
« Reply #1 on: April 17, 2012, 02:17:49 PM »
Give RibbonNinja a try.
huiz
  • Certified Prof C3D
« Reply #2 on: April 17, 2012, 02:22:01 PM »
You can access the Ribbon Tabs by typing +RIBBON on the commandline.
I assume you can do that too in Lisp.
Command: +ribbon
Enter <menugroup name>.<element id> of the tab to make active (e.g. ACAD.ID_TabHome):
BlackBox
« Reply #3 on: April 17, 2012, 02:25:35 PM »
At the link posted above, the source code is shared, so you could easily rename the LispFunction Method to suite... +Ribbon, etc.. This make me want to code a new 'CTabR' , or 'RibbonTab' sysvar. *geek*
trogg
« Reply #4 on: April 17, 2012, 02:58:06 PM »
Awesome guys!!
thanks. The +RIBBON command works great
We have users who freak out if they open up AutoCAD and it isn't on the home tab.... This can easily be added so that they "feel right at home..."
~Greg
alanjt
  • Standby for witty remark...
« Reply #5 on: April 17, 2012, 03:28:07 PM »
Command: +ribbon
:kewl:
Dropbox
andrew_nao
« Reply #6 on: May 16, 2013, 11:38:55 AM »
old topic, but was or has anyone been able to get this to work via lisp?
huiz
« Reply #7 on: May 16, 2013, 02:04:11 PM »
Yup.
(command "+RIBBON" "ACAD.ID_TabAnnotate")
The names of the tabs you can get from CUI.
andrew_nao
« Reply #8 on: May 16, 2013, 02:29:25 PM »
that line (with my tabs), mixed in other lines of code for me refuse to work.
i thought maybe someone found an alternate way to do this
huiz
« Reply #9 on: May 16, 2013, 04:08:19 PM »
You need to refer to the CUI (or groupname) which contains the tabs as well. Maybe you have Map3D loaded? Or Civil3D?
The tab ID_TabAnnotate can be found in the group ACAD, so you call ACAD.ID_TabAnnotate to activate it. But if your groupname is different, you need to use that.
2cook2
« Reply #10 on: January 29, 2014, 04:55:29 PM »
Just to clarify.
+RIBBON Enter <menugroup name>.<element id>
<menugroup name> = The name of the cui the tab is found in
<element id>            = Found in the cui of that tab
See attached image.
Also, these are case sensitive!!
Andrea
« Reply #11 on: April 30, 2018, 02:00:55 PM »
Hi all,..
I just read this topic,..
but,..anyone test this +ribbon with CAD 2018 / 2019 ?
it seem not working other then ACAD menu..
Thank you.
Keep smile...
huiz
« Reply #12 on: April 30, 2018, 02:07:41 PM »
No problem in Civil 3D 2019:
(command "+RIBBON" "CIVIL.ID_Civil3DHome")
« Reply #13 on: April 30, 2018, 02:11:25 PM »
Works here too in vanilla 2018.
MSTG007
« Reply #14 on: April 30, 2018, 05:18:31 PM »
That is slick... Works in Civil3D 2018.
Civil3D 2020
