Author Topic: BURST command...  (Read 3148 times)
Andrea
BURST command...
« on: August 19, 2004, 06:19:43 PM »
Hi, I would like to know how to use the BURST command from expresstool
in a lisp..
ex:
(command "burst" item1 "")
is there a way to do that ?
any suggestions will be appreciated.
thanks. :wink:
Keep smile...
  • Custom Title
BURST command...
« Reply #1 on: August 19, 2004, 07:08:21 PM »
Look at the code for burst, it should tell you.
Slim©
  • The Dude Abides...
BURST command...
« Reply #2 on: August 19, 2004, 07:33:29 PM »
Burst is a lisp program, and I do not believe you can re-enter lisp from lisp.
AVCAD
BURST command...
« Reply #3 on: August 26, 2004, 03:46:14 PM »
Are you sure there is no way to run a LISP routine within a LISP....that sounds sort of stupid if you cant....
But I am having the same problem...
It works in a SCript file so why cant you use a LISP file....
BURST command...
« Reply #4 on: August 26, 2004, 03:56:37 PM »
If it is a lisp based command you should be able to utilize it thusly ...
(c:burst)
But really, said command doesn't do anything that cannot be replicated in your own code if you just take the time to itemize what it does.
Craig
BURST command...
« Reply #5 on: August 26, 2004, 03:57:07 PM »
You can call a lisp from a lisp as long as the lisp routine your wanting to use is setup as a command. Kind of like
(defun c:t1 ()
  (alert "\nHello " )
  (c:burst)
  (alert "\nGoodbye ")
But you can't supply a variable from one routine to another one "item1"
Craig
BURST command...
« Reply #6 on: August 26, 2004, 04:10:25 PM »
This is what the error will be when you try do what your asking
Can't reenter LISP.
*Invalid selection*
