I have a block that has 17 attributes with the same tag. Nevermind why it is that way. My problem is I need a routine that can update all of the attributes at the same time by typing the desired text only once. I have tried to write my own but alas my experience is too little. I need this to work for only the selected block because this block is inserted into the drawing multiple times. I have attached the block in question. Help anyone?
Thanks in advance,
Reuben Shilling
