Author Topic: Are you a MEMBER?  (Read 2469 times)
  • Custom Title
Are you a MEMBER?
« on: December 08, 2005, 07:04:32 AM »
What can you do with the MEMBER function?
Well let's see ...
(setq lst '( 1.0 2.25 3.15 5 0.25 ))
(member 2.25 lst)
==> (2.25 3.15 5 0.25)
(car (member 2.25 lst))
==> 2.25
(member (+ 2.5 2.5) lst)
==> (5 0.25)
That's pretty cool uh.
(setq i '((1 2 3)(4 5 6)("a" "b" "c")))
(member '(4 5 6) i)
==> ((4 5 6) ("a" "b" "c"))
(member 5 (car (member '(4 5 6) i)))
==> (5 6)
(defun c:vote (/ answers question)
  (setq answers '("yes" "no" "maybe"))
  (setq question (getstring "\nDo you like ACAD 2006? "))
  (if (member (strcase question t) answers)
    (princ "\nThanks for voting")
    (princ
      "\nSorry I can only accept \"yes\" \"no\" or \"maybe\""
nivuahc
Re: Are you a MEMBER?
« Reply #1 on: December 08, 2005, 07:10:34 AM »
Hope you don't mind, I updated your code a bit:
    (princ
      "\nPlease refrain from using expletives and answer \"yes\" \"no\" or \"maybe\" only"
command: vote
Do you like ACAD 2006?  It's driving me up the $%#*@ WALL!!!!!
Please refrain from using expletives and answer "yes" "no" or "maybe" only
command:
hudster
« Reply #2 on: December 08, 2005, 07:21:40 AM »
 :-D
whdjr
« Reply #3 on: December 08, 2005, 08:14:39 AM »
Catchy title Mark.  :-)
Joe Burke
« Reply #4 on: December 08, 2005, 09:17:03 AM »
Member if you need the list it returns. Otherwise, vl-position to simply test for an item in a list.
