Author Topic: about angbase system variable  (Read 3632 times)
DEVITG
« on: February 08, 2005, 07:33:06 PM »
When I change the angbase I get this
Could you explain me what it is , why the 5157
I understand that the value to input shall be in the same units as stated on the AUNITS
Command: setvar
Enter variable name or [?] <ANGBASE>:
Enter new value for ANGBASE <5157>: 90
Command:
SETVAR Enter variable name or [?] <ANGBASE>:
Enter new value for ANGBASE <270>:
Command:
Enter new value for ANGBASE <270>: 90
Command:
Enter new value for ANGBASE <270>: 'cal
>> Expression: 3.14/2
1.57
Command: setvar
Enter new value for ANGBASE <358>:
« Reply #1 on: February 09, 2005, 08:44:59 AM »
You have ANGDIR set to clockwise
Change the value of ANGDIR to 0 and the angles will be correct when you set them. If you change the value of ANGBASE with ANGDIR set to 1, AutoCAD automatically rotates the angle by 180 degrees. So 90 would be 270 and 270 would be 90. The result is the same regardless, it is just automatically adjusting for the clockwise angle direction.
DEVITG
angdir angbase
« Reply #2 on: February 09, 2005, 04:47:53 PM »
Guess I need to draw a piece  clockwise and with angbase as 90 north.
How should I do it?
Thans in advance
