Author Topic: PC3 ...  (Read 2988 times)
Andrea
PC3 ...
« on: April 12, 2005, 05:09:51 PM »
I have configured AutoCAD to take PC3 file located to a specific folder in search path directory and it work well,
But how can i remove the existing printer..?
 ex:
HP laserjet 4MV
\\server\printer
FORMAT1.PC3
Keep smile...
whdjr
PC3 ...
« Reply #1 on: April 12, 2005, 05:29:56 PM »
Maybe remove the original search path...?
Andrea
PC3 ...
« Reply #2 on: April 14, 2005, 10:50:39 AM »
Quote from: whdjr
allrady removed....but still the same. :cry:
Keep smile...
Kate M
PC3 ...
« Reply #3 on: April 14, 2005, 12:38:01 PM »
Are you trying to get rid of a *printer* or a PC3 file?
pmvliet
PC3 ...
« Reply #4 on: April 14, 2005, 12:41:57 PM »
tools, options, plotting tab. for 2k2 and 2k4 it is in the lower left hand corner. Select Hide system plotters.
for 2k5 and maybe 2k6, plot and publish tab, right side about 2/3rd down
there is Hide system printers.
probably would be a variable somwhere that it could be set....
need to look into that as that would be helpful...
Pieter
MikePerry
PC3 ...
« Reply #5 on: April 14, 2005, 05:31:51 PM »
Hi
(getenv "HideSystemPrinters") ;Returns current value
(setenv "HideSystemPrinters" "1") ;Hide Windows System Printers
Please note that Environment Variables as case sensitive ie. UPPERlower case is important, therefore for the above to work, type as shown.
Have a good one, Mike
whdjr
PC3 ...
« Reply #6 on: April 14, 2005, 05:35:59 PM »
I tried this in Acad2000 and it let me set it, but it didn't do anything. :?
MikePerry
PC3 ...
« Reply #7 on: April 14, 2005, 05:43:05 PM »
Quote from: whdjr
Hi
It should work from AutoCAD 2000 upwards....
Works in AutoCAD 2002, 2004 & 2005 (sorry they are the only ones I can test on at the moment).
whdjr
PC3 ...
« Reply #8 on: April 15, 2005, 08:28:55 AM »
I checked the Environment Variables PDF from the AutoCAD website and it's supposed to work but mine still show up...oh well. :?
Andrea
PC3 ...
« Reply #9 on: April 15, 2005, 08:54:30 AM »
Quote from: MikePerry
Hi
Mike,
Exactly what i need....
thanks.
Keep smile...
pmvliet
PC3 ...
« Reply #10 on: April 15, 2005, 01:15:45 PM »
Thanks Mike!
