Author Topic: AutoCAD 2013 and Map API functionality  (Read 1628 times)
cannorth
« on: November 14, 2012, 12:48:21 PM »
Hello,
  I have this code that I'm trying to run in AutoCAD 2013:
        Dim ds As DrawingSet = proj.DrawingSet
        ds.AttachDrawing(roads_dir_string & "Roads-BC.dwg")
  Would this still work in AutoCAD 2013?  Would there be any new dll reference changes or anything like that for it to work?
Thanks,
cannorth
cannorth
Re: AutoCAD 2013 and Map API functionality
« Reply #1 on: November 19, 2012, 03:18:26 PM »
I solved this.  The problem was that I needed a drive alias in AutoCAD refering to the network drive.
