Author Topic: 2005 Vanilla or ADT?  (Read 3224 times)
Martin-Y
« on: March 17, 2004, 06:32:36 AM »
We are currently on ADT 3.3 only because the last upgrade was offered at the same price as vanilla. As the ADT upgrade is £300 dearer than vanilla my question, is ADT worth it. Most of my work is Civil engineering below ground and I have no use for doors and windows etc.
Would I be better of picking up say "Autosolids" as an add-on that would give me parametric modelling, as I do frequently create 3d models. I still need Autocad for a reinforcement package that I use.
Dent Cermak
« Reply #1 on: March 17, 2004, 08:25:13 AM »
You are doing Civil work with ADT? Why ? What you need is LDD . LDD contains the Civil pac, the Survey pac and MAP. An architectural pac doesn't do civil very well. Your reseller messed over ya'll big time and sold you something totally innappropriate for your needs. It's time to open a big ole can of whupass.  :twisted: You'll like the profile and and underground utility routines in LDD (Land Developement Desktop). I know it sounds like it's just a survey pac with that name, but it is MUCH more.
Martin-Y
« Reply #2 on: March 17, 2004, 12:41:23 PM »
Actually its not as bad as it sounds, we are still doing concrete profile just that it is all substructure. Oddly enough I did look at LDD some years back but the software developer that I rely on for my reinforcement wouldn't guarantee that it was compatible, they also promised more functionality with ADT (never actually happened).
Now reinforcement in 3d...., that would be an advance!!
PDJ
« Reply #3 on: March 17, 2004, 01:32:04 PM »
Dude, you seriously need to look at LDD again. With LDD you can import your survey shots into AutoCad, draw a polyline where you want your alignment to run, a couple of clicks later, you're looking at a profile of your alignment created by LDD.  With architectural desktop, you'll still be wondering which way the door swing goes.
I've often said LDD is to AutoCad what AutoCad was to manual drafting.  Make sure you take a decent class with the purchase as well. It'll be well worth the time and money.
Paul Jordan
Anchorage, AK
Hangman
ADT ...
« Reply #4 on: March 17, 2004, 03:39:13 PM »
Well, ...  I use ADT, I think its ...
A piece.
Granted, adork came a long way from what they had in R12 and 14, but, I'd take the advice of those before me, Look at LDD and some other items.
ADT is NOT worth the 300 bones you've gotta fork out.   :x
daron
Re: ADT ...
« Reply #5 on: March 17, 2004, 04:19:57 PM »
Quote from: Hangman
Unless of course, you're using it for..... ARCHITECTURAL work, which it was designed for.
Dent Cermak
« Reply #6 on: March 17, 2004, 06:51:25 PM »
Talk your boss into a copy of LDD. You then will have every tool you ever dreamed of. What ain't there the guys here can write for you. Much of LDD will come easily to you because the ADT set up is similar to LDD's. Then go to www.agtcad.com and order the training CD's. Buy a thick bath towel. When the CD's arrive to show you what LDD will do and how to do it, be sure to place the thick towel in your lap. This will keep you from ruining your pants and chair as you stare in awe and disbelief at what you will be able to do. This level of awe usually involves slobbering, hence the need for the towel.
Profiles, alignments, x-sections, surfaces underground utility design, it's all there just waiting. It's not in ADT. And no, I do not work for AutoDesk. I work for a surveying and mapping firm and use this monster daily. We do road alignments and stake out, volume computations, topo maps, GPS etc., etc. All in LDD. ADT cannot do this. Use the right tool for the job and you will work faster and you boss will bubble with delight. (or maybe he just bubbles cause he's old like me. I bubble all the time.)   :oops:
Martin-Y
« Reply #7 on: March 24, 2004, 07:37:33 AM »
Dent
Just looking on Adesk site and seen a new (to me anyway) companion to LDD called Civil 3d. Starting off life as an extension on the subscription programme but looks as though it may become the fully fledged replacement for LDD. You seen it yet?
Martin-Y
« Reply #8 on: March 24, 2004, 11:02:59 AM »
Sorry, just seen your post in land lubber
