Cab, which have easy to program, you know I have a routine that makes sections of reinforced concrete beams, perhaps could be adapted to make the section of the pedestal, but that routine has a problem with the dim ... I work as model I give the scale to the window, so that the drawing is to scale papespace appropriate (not if I explain it), I use styles dim (20 - 25 - 50 - 75 - 100), the ideal would be that the routine could work with these styles of dim. Also I have another routine that is for the reinforcement of foundations, drawing on plant, would also have to adapt, I use cad 2010 and I have not been able to use.I hope I can adapt and make a great routine sections of foundation.
I hope not too much trouble all I need.
Thank you again.
