Author Topic: How to Entmake region?  (Read 6629 times)
HasanCAD
Re: How to Entmake region?
« Reply #15 on: January 24, 2011, 07:57:07 AM »
(5) that is what you need?
Perfect
How to sort object refer to its area?
(4) boolean (the Max area region)-(the other region).
qjchen
  • Best wishes to all
« Reply #16 on: January 24, 2011, 08:14:22 AM »
((bound1-name area1) (bound2-name area2)....), then vla-sort  :)
http://qjchen.mjtd.com
HasanCAD
« Reply #17 on: January 24, 2011, 08:57:54 AM »
Could I call a command then use VLA-***
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #18 on: January 24, 2011, 09:08:47 AM »
(vla-sendcommand (vla-get-activedocument (vlax-get-acad-object)) "your command string")
