Elaboration:
I have an area that I am trying to obtain a storage volume in. The problem that I am running into, is that the surveyors didn't get enough information in key locations to obtain a reliable tin. I have a couple of islands in the middle of the area, the surface is ignoring portions of the curbing, due to a lack of survey information. If I could retreive the contour information in a fashion that I could modify (digitize, etc.) the contours, I could force the tin to model the actual surface more closely. So, what I am looking for, is a way to extract the contours from the surface to grip edit them and then recreate the tin based on the new (modified) contour information.
